Internally Regulated Over Voltage Protection
BMC_Dave
PostPosted: Sun Jan 13, 2019 8:01 pm    Post subject: Internally Regulated Over Voltage Protection Reply with quote
I see that schematics for providing over voltage regulation on internally regulated alternators have been scrubbed: http://www.aeroelectric.com/DIY/DIY_Crowbar_OVP_F.pdf
Looks like the last rev was in 2005. Has there been any changes in thinking in the last 14 years as to the use of internally regulated alternators? Is there possibly an example of this safety features use on an IR alternator I can see so I can at least have the information? Any help is greatly appreciated, thanks.
BMC_Dave
PostPosted: Sun Jan 13, 2019 9:01 pm    Post subject: Re: Internally Regulated Over Voltage Protection Reply with quote
After finding Z-24 I wonder if leaving the ebus alt feed closed normally would help with load dumps for in flight switching off of the alternator?
The easiest solution is to turn off the engine first when shutting down.
BMC_Dave
PostPosted: Mon Jan 14, 2019 10:47 am    Post subject: Re: Internally Regulated Over Voltage Protection Reply with quote
Adding to the questions, are there any negatives to leaving the e-bus alt feed closed for normal operations? Or would an additional diode between the e-bus alt feed and diode be prudent to avoid alternators trying to charge the battery through the alt feed?
BMC_Dave
PostPosted: Tue Jan 15, 2019 3:10 pm    Post subject: Re: Internally Regulated Over Voltage Protection Reply with quote
Bueller
PostPosted: Tue Jan 15, 2019 5:41 pm    Post subject: Re: Internally Regulated Over Voltage Protection Reply with quote
Most of the battery charging current will come through the battery contactor.
Very little, if any will pass through the E-Bus diode. Another diode between
the battery and E-Bus is not desired because it will drop voltage. Not good if the battery voltage is low.
Joe Gores
BMC_Dave
PostPosted: Wed Jan 16, 2019 9:50 am    Post subject: Re: Internally Regulated Over Voltage Protection Reply with quote
Awesome, thank you.
