Mono Trailer Ramp extenders
clivesutton
PostPosted: Sat Jan 12, 2019 3:34 am    Post subject: Mono Trailer Ramp extenders Reply with quote
I'm having some 'U' channel made for my Mono trailer - to extend it and make the loading/unloading operation easier. Essentially the ramp will be made from two pieces of 500L x 80D x 225W folded from 6mm Alu plate, hinged so that it works as the factory design when loaded but extends the inclined ramp portion to be 500mm further from the trailer 'hod' the main wheel sits in.
The min qty is 8 pcs and i will use 2 - so i'm wondering if anyone else would like to buy the surplus pieces? Cost will be ~£60 each. Polyester powder coated in white as attached drawing.
Any takers/interest?
Clive
AHA B3PD401B Trailer Ramp.pdf
Download
 Filename:  AHA B3PD401B Trailer Ramp.pdf
 Filesize:  31.09 KB
 Downloaded:  413 Time(s)
