Stratux alternative ADS-B antennas?
farmrjohn
PostPosted: Wed Jan 02, 2019 12:42 pm    Post subject: Stratux alternative ADS-B antennas? Reply with quote
Hi, new to the list. I'm interested in a Stratux for ADS-B in but would prefer a less visible antenna array for the ADS-B. Are there alternatives? I'm planning on powering the unit via aircraft power/USB cable and not using it as a portable.
John
farmrjohn
PostPosted: Sat Jan 05, 2019 3:34 pm    Post subject: Re: Stratux alternative ADS-B antennas? Reply with quote
I have received the components and assembled the Stratux. Is the reason it uses two separate antennas for the two ADS-B frequencies because the computer board takes two USB receivers, one for each frequency. Some other integrated ADS-B in receivers can utilize a single antenna which can be remote. Would that be due to different circuitry inside the unit? It would be nice to get rid of the “rabbit ear” antennas I the cockpit. Any help/comments appreciated. John
rick(at)beebe.org
PostPosted: Sat Jan 05, 2019 9:27 pm    Post subject: Stratux alternative ADS-B antennas? Reply with quote
Yes, there are two different receivers in there, each with its own antenna. You could use a tee to tie one antenna to both receivers I guess. Personally I like that each receiver gets an antenna optimized for its particular frequency. You can certainly remote mount the two antennas. Open Flight Solutions sells a plastic holder with a suction cup to hold them in a rear window, for instance. I've also seen some 3D printed versions on, probably, thingiverse.
The Stratux is built on a Raspberry Pi single board computer and a couple software defined radios. I'm pretty sure every other ADS-B receiver has custom receiver and decoder circuitry inside it.
--Rick
On 1/5/2019 6:34 PM, farmrjohn wrote:
--> AeroElectric-List message posted by: "farmrjohn" <faithvineyard(at)yahoo.com> (faithvineyard(at)yahoo.com)
http://forums.matronics.com/viewtopic.php?p=486750#486750
farmrjohn
PostPosted: Sun Jan 06, 2019 9:03 am    Post subject: Re: Stratux alternative ADS-B antennas? Reply with quote
Thanks for the tip on the remote mount. Now I'm also considering switching to the remote gps antenna. That way the stratux could be mounted in the shade vs. in direct sunlight even though it has a built in fan. John
--Rick
