Are you ready for Requirements For The Collection of Glass
ahwhglass
PostPosted: Sun Dec 23, 2018 11:45 pm    Post subject: Are you ready for Requirements For The Collection of Glass Reply with quote
The glass used for that glass curtain wall need to be safety glass, mainly like Building Tempered Glass, laminated (glued) goblet, insulating glass, fireproof tumbler, solar control coated cup and low-emission coated glass (High Transmission Low-E Glass). The specific selection requirements are seeing that follows:
1. Safety glass need to be used for the curtain wall. The thickness on the glass should not be below 6mm. The thickness from the full glass curtain wall rib glass can't be less than 12mm.
COUPLE OF. The appearance quality in addition to technical index of drift glass used for heat-reflecting coated glass shall abide by the requirements of excellent products or first-class products in the current national standard "Float Glass".
SEVERAL. The insulating double glazed windows belonging to the curtain wall should end up being sealed with two stations.
The insulating glass from the exposed frame curtain wall should be made of polysulfide sealant and butyl sealant. The insulating glass of the semi-hidden frame curtain wall will likely to be made of silicone structural sealant as well as butyl sealant; the coated surface should be the second of the actual insulating glass. Or for the third side.
4, the laminated glass with the curtain wall should be processed by polyvinyl butyral (PVB) picture dry processing of laminated cup. The thickness of your interlayer film (PVB) with the point-supported glass curtain wall structure laminated glass shall not be not as much as 0. 76 mm.
5, tempered glass should adhere to the provisions of GB9963 "tempered glass".
A FEW. All curtain wall glass really should be edge treated.
