Building: Fitting the fuselage through the window?
sim(at)4lists.simonliebol
PostPosted: Wed Dec 19, 2018 10:23 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Dear builders - former and current,
I'm currently in the process of finding a suitable place to build. I've
been offered a couple of rooms that could be turned into a work shop in
a building around the corner. But the big drawback: The widest opening
is a 130cm x 130cm (51'' x 51'') large window. Will this be of use to
complete at least some of the building stages? I thought about building
the fuselage and moving it outside for engine installation.
It's a mono-wheel. The fuselage width is stated as 1.12m. So this should
be OK. The hight is stated as 1.59m, but this is main-wheel to top of
the vertical stabilizer. It should be less when measured from the
tail-wheel. Plus, the fuselage could be rolled 45° when moving the tail
through the window. With plenty of help, of course.
Is this feasible or should I walk away from this offer? Did you work
shops have similar limitations?
All the best,
Simon
freddythek10(at)gmail.com
PostPosted: Wed Dec 19, 2018 10:32 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Is the wall which this opening is located within constructed of wood or masonry?
All the best,
Simon
PostPosted: Wed Dec 19, 2018 11:41 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Am 19.12.18 um 19:32 schrieb Fred Klein:
It's masonry. I think the owner would disapprove if I tried to make it
larger.
Simon
gilles.thesee(at)free.fr
PostPosted: Wed Dec 19, 2018 12:58 pm    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Hi Simon,
That's plenty of room to move the fuselage through a window.
It all depends of what level the window is. Ground level would be
perfect. Concerning the tail, do you have enough room inside to move the
fuselage around so as to insert the tail first ? Or room outside to do
the reverse ?
Of course, you won't install the wheels before getting the fuse through
the window.
Why not print a side view of the fuselage at a definite scale and try it
on a plan ?
I've seen many a fuselage getting through much narrower apertures.
Best regards,
Gilles
http://contrails.free.fr
PostPosted: Thu Dec 20, 2018 2:28 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Hi Gilles,
Am 19.12.18 um 21:57 schrieb GTH:
perfect.
Thanks. This sounds encouraging. It is ground level. Sorry, I forgot to
mention.
It is not huge on the inside (4,65m x 5,01m). But without cowling it
should barely fit. There is a second room that belongs to it (2m x
5.18m) to store smaller parts or the wings etc. The ceiling is at ca.
3.30m. I may be able to store parts underneath it when not working on it.
Or room outside to do the reverse ?
Yes, it is a corner room and both windows have enough room on the
outside. It's a former train station building.
through the window.
It's a mono wheel. I could imagine that it could even fit with the main
wheel installed. I remeasured the window. It is actually a bit larger
than initially thought. 1,40m x 1,40m.
it on a plan ?
Good idea. I will try that.
I took photos of the room, if anyone wants to take a look:
https://photos.app.goo.gl/zpurAR6q4TwX3H8C7
Kind regards,
Simon
PostPosted: Thu Dec 20, 2018 7:29 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
A watchword for building the Europa when working on the fuselage is to delay the bonding of the top to the canoe for absolutely as long as possible...thus there is a considerable amount of work which can be done without worrying... and when that’s all finished, you’ll want to trial fit with clecoes, after which you can give it a go thru the window...no harm done.
On Dec 20, 2018, at 2:27 AM, Simon <sim(at)4lists.simonliebold.de> wrote:
Hi Gilles,
> perfect.
mention.
> through the window.
> it on a plan ?
Kind regards,
Simon
PostPosted: Thu Dec 20, 2018 8:18 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Hi Simon,
Rooms seem most adequate.
A 3.30 m ceiling is quite interesting.
wheel installed.
Maybe you'll be better off with setting up wheels etc. inside, then removing them to save weight for the delicate maneuver ?
At first thought, the idea would be to turn the fuselage on it's side, then somehow "thread" the fuselage through the aperture :
[img]cid:part1.C185672A.A456B807(at)free.fr[/img]
All the best,
Kind regards,
Gilles
 Filesize:  2.47 KB
 Viewed:  6116 Time(s)
wdaniell.longport(at)gmai
PostPosted: Thu Dec 20, 2018 9:04 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Fred makes a very good  point.
Make a cradle which holds the bottom half in place from Firewall to tail.  My fuse has a slight twist (one end of the tail is 1cm lower than the other) which is the result of not supporting the tail
Put absolutely everything in with the top off including all the electrics and the instrument panel.  You could probably get the bottom half out easier and then glue the top on somewhere else.
Do remember that the canoe is very floppy and can break easily if not supported.
Will
XS tri 912 Turbo Airmaster Dynon Skyview 100 hours
On Thu, Dec 20, 2018, 10:31 Fred Klein <freddythek10(at)gmail.com (freddythek10(at)gmail.com) wrote:
--> Europa-List message posted by: Fred Klein <freddythek10(at)gmail.com (freddythek10(at)gmail.com)>
> On Dec 20, 2018, at 2:27 AM, Simon <sim(at)4lists.simonliebold.de (sim(at)4lists.simonliebold.de)> wrote:
> --> Europa-List message posted by: Simon <sim(at)4lists.simonliebold.de (sim(at)4lists.simonliebold.de)>
> Hi Gilles,
>> perfect.
> mention.
>> through the window.
>> it on a plan ?
> Kind regards,
> Simon
br> fts!)
r> > e.com" rel="noreferrer noreferrer" target="_blank">www.mypilotstore.com
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
PostPosted: Fri Dec 21, 2018 5:32 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
Hi all and thanks for the helpful hints and especially for pointing out the importance of the alignment part and the part on insurance. I have to admit, I didn't think about that. It would make sense to contact a few insurers to get an idea about the difference in premiums.
The kit came with Hi-Top Mod-64 (non-B) mod. However, I'm not sold yet on incorporating it. I would add complexity during the build. I am not tiny but also no basketball player (1.82m or 5ft 11.7in).
I will try to answer all the question in a single message:
[img]cid:part1.C4498FC2.AA04CC73(at)4lists.simonliebold.de[/img]
Thanks Gilles, I like your drawing.
I bought the kit together with a cradle on wheels: https://photos.app.goo.gl/bpsFAz7fn1i4dTWu6 I think it will come handy throughout the built.
Nice size windows. How much does the window open? Or can the window be easily removed when needing to transfer? P
I think they open 90° to the side. I will have a chance to test it tomorrow when I meet to discuss the financial bit.
Simon
p.s.
Lancaster, Pa. USA
This was a stop on my solo x-country years back. Aww, memories...
 Filesize:  3.67 KB
 Viewed:  6094 Time(s)
peterz(at)zutrasoft.com
PostPosted: Fri Dec 21, 2018 6:02 am    Post subject: Building: Fitting the fuselage through the window? Reply with quote
FWIW wrt headroom, I am 6' (and shrinking lol), but with a 6'2" seat height, so always have difficulty with headroom in every plane I sit in.
On my kit, I am cutting and lowering the cockpit module seat wedge (I have Andy's approval from way back when)  as far as possible (still accommodating the glider brake control etc), which puts me in a more prone position and gives me the required headroom without ugly bubble windows, or RV-12 looking hi-top pudginess Wink.  The stock fuse shape is just so sweet and efficient.  To make up for my loss of legroom, I am removing the panels bottom "switch" ledge..... lots of panel room these days when going all-glass.
an aside: I am still amazed how Richard V, ripped off the Europa design elements and threw them together into the slow and dorky pop-rivet RV12.
Cheers and good luck!
Pete
A239
On Fri, Dec 21, 2018 at 8:41 AM Simon Liebold <sim(at)4lists.simonliebold.de (sim(at)4lists.simonliebold.de)> wrote:
[img]cid:167d101c2eb110c5b3d1[/img]
Simon
p.s.
Lancaster, Pa. USA
 Filesize:  3.67 KB
