Need help with some Z-14 electrical system troubleshooting
Mauledriver(at)nc.rr.com
PostPosted: Tue Nov 27, 2018 11:05 am    Post subject: Need help with some Z-14 electrical system troubleshooting Reply with quote
(the Z-14 has 2 buses, 2 alternators and 2 batteries - B&C alternators
and regulators, Odyssey batteries)
I regularly fly with the 2 buses not interconnected.  At cruise I've
been seeing between 14.5 and 14.7 volts on both buses.  I've been
running like that for over a year.
On my last flight I noticed the voltage on bus 2 dropped almost 1 volt.
It was jumping around between 13.4 and 14.0 volts.  I removed various
loads to see if perhaps I had a malfunctioning component but this had no
effect.
I engaged the cross feed to connect the 2 buses.  Bus 2 remained at 14
volts or less but was less jumpy staying closer to 14.  Bus 1 remained
at 14.5 to 14.7.
With the cross feed engaged and Bus 2 switched off, the voltage on Bus 2
dropped to between 12.4 and 13.7
With the cross feed engaged, I pulled the CB on the bus 2 regulator
taking the #2 regulator/alternator offline.  Bus 2 voltage was between
12.8 and 13.5 (bus 1 was 14.5)
I don't have a load tester but the bus 2 battery seems okay (12.78volts
with no load at 50F).  It would seem that I'm getting some current from
the alternator but there has been a distinct drop in bus 2 voltage.  I
would have thought that both buses would have roughly the same voltage
when interconnected with the bus 2 alternator offline.
I'm looking for some advice on troubleshooting.  Thanks!
skywagon185(at)gmail.com
PostPosted: Wed Nov 28, 2018 10:28 am    Post subject: Need help with some Z-14 electrical system troubleshooting Reply with quote
A rough guess would be that the alternator possibly has lost one of its high current diodes.
On Tue, Nov 27, 2018 at 11:10 AM Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
--> AeroElectric-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
effect.
at 14.5 to 14.7.
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
WIKI -
