ADS-B out and in
Pfatchantz(at)protonmail.
PostPosted: Mon Nov 26, 2018 6:06 am    Post subject: ADS-B out and in Reply with quote
Ads b "in" is decently explained on youtube ....I  believe it can be accomplished for under 100 bucks....I set it up with a Raspberry pi II and the NooElec dongle and free software for under 75 dollars...Hock shop tablet for portable use ...cost me  50 dollars..  The only thing I wanted was  the weather radar... Will need a power supply adapter when flying...... Herb
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Sunday, November 25, 2018 8:03 PM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
[quote]Nick, Have you looked at Dynon's new portable ADSB? in their Avweb announcement the price right now is $395.
http://dynonavionics.com/drx-portable-adsb.php
Rick
On Thu, Nov 22, 2018 at 6:28 PM John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
Thanks, Arty.
This FAA Pub spells it out pretty well, well enough for me to grasp and understand.
https://www.faa.gov/nextgen/equipadsb/research/
I've been able to fly all over the US, Canada, and Alaska, without having to enter airspace where ADS-B would be required.  Don't think I'll have a requirement for it in the future.
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of TheWanderingWench
Sent: Thursday, November 22, 2018 12:43 PM
Subject: Re: Kolb-List: ADS-B out
John -
If you never (or very seldom) fly into ADS-B-designated airspace, then there is no requirement to equip.  A number of my friends and I are not going to install, because we don't fly in/through that airspace. AND because you can request an authorized deviation from ATC if you are not equipped. Check out Federal Regulation 14 CFR Β§ 91.225 and 14 CFR Β§ 91.227 for specific info.
Have a great Thanksgiving.
Arty
Sandy, Oregon
 "I refuse to tip toe through life just to arrive safely at death."
On Thursday, November 22, 2018, 10:28:08 AM PST, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
I too am out in the country, definitely not desert.  Wink
Also sorry to say I have not read the first requirement for ADS-B, but have seen it mentioned and advertised many times.  Am I missing a requirement that I should have installed on my MKIII?
BTW:  Happy Thanksgiving to all my Kolb friends.  Thanks for being there for the past 34 years on this wonderful Kolb flight.
hauck's holler, Titus, Alabama
Richard Pike
PostPosted: Wed Nov 28, 2018 8:07 am    Post subject: Re: ADS-B out and in Reply with quote
Pfatchantz(at)protonmail. wrote:
The only thing I wanted wasοΏ½ the weather radar... Will need a power supply adapter when flying...... Herb --
If all you wanted was the weather radar, I have the Raindar app on my phone that seems to work really well. Or maybe the ADSB is that much better? Have not seen it so I don't know. I do know that I have used Raindar when motorcycle riding to take the roads that keep me dry.
Here are the cell phone mounts on the MKIII and the FF. The MKIII has a charging usb adapter hard wired in, the FF has a little shelf as part of the bracket so that an external cell phone battery can be attached. Then it slips into the top of the control stick, a rivet in the stick keeps it aligned.
 Filesize:  131.78 KB
 Viewed:  5318 Time(s)
 Filesize:  77.02 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
PostPosted: Wed Nov 28, 2018 10:06 am    Post subject: ADS-B out and in Reply with quote
Richard
I did not say but I have the parts already...Nice tablet,Raspberry PiII+ and access to the power requirements...
I wanted the FAA radar...mainly...and also the adsb out reporting from other aircraft...as a minor benefit..
I experimented with it two or so years ago...Two years older and the brain will need a whole lot of stimulation from the net to get it going again...I have a nice 8 inch lg tablet and will use it... Pretty much need to be in the air to get the weather...since it is ground station sent while aircraft can be seen at home...Herb
On Wednesday, November 28, 2018 10:07 AM, Richard Pike <thegreybaron(at)charter.net> wrote:
> The only thing I wanted wasΓ―ΒΏΒ½ the weather radar... Will need a power supply adapter when flying...... Herb --
Richard Pike
Kolb Firefly Part 103 legal (Redoing the Firefly windshield)
Kingsport, TN 3TN0
http://forums.matronics.com/viewtopic.php?p=485843#485843
http://forums.matronics.com//files/p1070058_medium_404.jpeg
http://forums.matronics.com//files/p1070053_medium_153.jpeg
PostPosted: Wed Nov 28, 2018 6:12 pm    Post subject: ADS-B out and in Reply with quote
Guessing that the FAA weather could be satellite forwarded...? Herb
On Wednesday, November 28, 2018 12:06 PM, Pfatchantz <Pfatchantz(at)protonmail.ch> wrote:
Richard
On Wednesday, November 28, 2018 10:07 AM, Richard Pike thegreybaron(at)charter.net wrote:
> Richard Pike
> Kingsport, TN 3TN0
> Forgiving is tough, being forgiven is wonderful, and God's grace really is amazing.
