ceengland7(at)gmail.com Guest
Posted: Tue Nov 13, 2018 2:55 pm Post subject: Cheap bench supply? |
Anyone have experience with the recent ebay offerings for cheap lab supplies? Example below. I tried searching my old AEC emails, but the most recent reference I found was for a much more expensive model. It'll get minimal use; just final checkout of my project's wiring and then rare uses after that, so don't want to spend $hundreds.
0-30v/0-10a bench supply
Charlie
echristley(at)att.net Guest
Posted: Tue Nov 13, 2018 3:14 pm Post subject: Cheap bench supply? |
Looks very much like the onei bought from mpja.com. mine works perfectly.
Sent from Yahoo Mail on Android
Charlie
Posted: Tue Nov 13, 2018 3:39 pm Post subject: Cheap bench supply? |
Thanks, Ernest. Anyone else?
On Tue, Nov 13, 2018 at 5:18 PM Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote:
Quote: | Looks very much like the onei bought from mpja.com. mine works perfectly.
Charlie
brian.lester(at)gmail.com Guest
Posted: Tue Nov 13, 2018 4:25 pm Post subject: Cheap bench supply? |
A bit more expensive but I got this from amazon. DC Power Supply Variable,0-30 V / 0-10 A Eventek KPS3010D Adjustable Switching Regulated Power Supply Digital
https://www.amazon.com/dp/B073TW8H2S/ref=cm_sw_r_cp_api_qY16BbT9P9Y2P
But honestly the stuff on eBay looks about the same at a better price.
-Brian
On Tue, Nov 13, 2018 at 6:44 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
Eric Page
Posted: Tue Nov 13, 2018 5:45 pm Post subject: Re: Cheap bench supply? |
Charlie,
I’ve had a 0-60V 5A unit very similar to that one for several years. The electrolytic on its output once sizzled and smoked, but was easy to replace with a good Rubycon. You can expect any of the Chinese PSUs to have dubious caps from brands you’ve never heard of (CapXon, anyone?).
The adjustment pots aren’t from the ALPS catalog, so it’s not what I’d call a precision instrument, but if you’re not designing medical devices, it’ll probably get the job done, cheaply.
Eric
rickofudall
Posted: Tue Nov 13, 2018 5:47 pm Post subject: Cheap bench supply? |
Charlie, this is the one I bought on Amazon. .
https://www.amazon.com/Dr-meter-Single-Output-Switchable-Alligator-included/dp/B07D4FQ4CP/ref=sr_1_17?ie=UTF8&qid=1542159852&sr=8-17&keywords=bench+power+supply
Rick Girard
On Tue, Nov 13, 2018 at 6:29 PM Brian Lester <brian.lester(at)gmail.com (brian.lester(at)gmail.com)> wrote:
Quote: | A bit more expensive but I got this from amazon. DC Power Supply Variable,0-30 V / 0-10 A Eventek KPS3010D Adjustable Switching Regulated Power Supply Digital
-Brian
Charlie
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
Posted: Tue Nov 13, 2018 6:24 pm Post subject: Cheap bench supply? |
At 04:54 PM 11/13/2018, you wrote:
Quote: | Anyone have experience with the recent ebay offerings for cheap lab supplies? Example below. I tried searching my old AEC emails, but the most recent reference I found was for a much more expensive model. It'll get minimal use; just final checkout of my project's wiring and then rare uses after that, so don't want to spend $hundreds.
0-30v/0-10a bench supply |
That one is an excellent value.
I paid 3x that for a 0-30, 3A supply
15 years ago.
Posted: Tue Nov 13, 2018 7:09 pm Post subject: Cheap bench supply? |
Thanks, to Richard, Earnest and Bob. Looks like I need to go ahead & pull the trigger. I'll report when it comes in.
Charlie
On 11/13/2018 7:47 PM, Richard Girard wrote:
Rick Girard
-Brian
Charlie
John M Tipton
Joined: 07 Aug 2018 Posts: 45 Location: Devon - England
Posted: Wed Nov 14, 2018 1:01 am Post subject: Cheap bench supply? |
What’s wrong with a ‘cb’ type radio power supply, 13.8 volts, 3-5 amps, why do you need something giving variable volts/amps, are you really going to test your expensive electronics by playing around with varying these outputs —-
John
Sent from my iPad
----x--O--x----
On 14 Nov 2018, at 3:11 am, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Quote: | Thanks, to Richard, Earnest and Bob. Looks like I need to go ahead & pull the trigger. I'll report when it comes in.
Charlie
Rick Girard
-Brian
Charlie
Posted: Wed Nov 14, 2018 6:17 am Post subject: Cheap bench supply? |
Several reasons, John.
1) Powering avionics will not be the only reason I ever need a power supply. I've used the one I bought for several other electronics projects that required different voltages.
2) You can ramp down the voltage to see where a particular instrument stops working. Useful for planning alternator out situations.
3) The ability to limit current allows you to safely test "experimental" electronics. Apply voltage at 1/2 an amp will let you test a circuit that may have a short.
On Wednesday, November 14, 2018, 4:03:06 AM EST, John Tipton <john(at)tiptonuk.eu> wrote:
JohnSent from my iPad
----x--O--x----
Thanks, to Richard, Earnest and Bob. Looks like I need to go ahead & pull the trigger. I'll report when it comes in. Charlie On 11/13/2018 7:47 PM, Richard Girard wrote:
Rick Girard
Quote: | A bit more expensive but I got this from amazon. DC Power Supply Variable,0-30 V / 0-10 A Eventek KPS3010D Adjustable Switching Regulated Power Supply Digital ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Quote: | Looks very much like the onei bought from mpja.com. mine works perfectly. Sent from Yahoo Mail on Android
Charlie
-- “Blessed are the cracked, for they shall let in the light.” Groucho Marx
Posted: Wed Nov 14, 2018 7:03 am Post subject: Cheap bench supply? |
Bingo. Ability to adjust voltage and limit current can minimize damage if somethings not right. Biggest exception is 'switcher' power supplies; they are trickier to test that way.
Charlie
On Nov 14, 2018, at 8:24 AM, Ernest Christley <echristley(at)att.net (echristley(at)att.net)> wrote: Quote: |
----x--O--x----
Rick Girard
Charlie
cluros(at)gmail.com Guest
Posted: Wed Nov 14, 2018 7:57 am Post subject: Cheap bench supply? |
I have been thinking of getting one of these as well but a 30V 20A model. I
have used one before but I'm not entirely sure how they work. What is the
function on the amperage dial? In what situation would you set it lower
than the maximum output of the power supply?
On Wed, Nov 14, 2018, 04:06 John Tipton <john(at)tiptonuk.eu wrote:
[quote] What’s wrong with a ‘cb’ type radio power supply, 13.8 volts, 3-5 amps,
outputs —-
John
Sent from my iPad
----x--O--x----
Charlie
Rick Girard
On Tue, Nov 13, 2018 at 6:29 PM Brian Lester <brian.lester(at)gmail.com>
> -Brian
> On Tue, Nov 13, 2018 at 6:44 PM Charlie England <ceengland7(at)gmail.com>
>> On Tue, Nov 13, 2018 at 5:18 PM Ernest Christley <echristley(at)att.net>
>>> perfectly.
>>> <https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature>
>>> <https://www.ebay.com/itm/10A-Digital-DC-Power-Supply-Variable-Adjustable-Lab-Bench-Test-Equipment-Tool/202435783331?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649>
>>> Thanks,
>>> Charlie
<http://www.goodreads.com/author/show/43244.Groucho_Marx>
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon> Virus-free
Posted: Wed Nov 14, 2018 10:05 am Post subject: Cheap bench supply? |
For my purposes at the moment, the current setting would be used to minimize risk of catastrophic failure in a device that's polarity sensitive, such as electronics, or possibly external stuff around a DC motor that might get hooked up backward. The way I'd use it is to set voltage to zero, and current to some relatively low percentage of a given device's max current draw. Apply power to the device, and slowly increase voltage while monitoring current and the device 'waking up'. The current limiter may well reduce the voltage below set point, to control current, if there's an 'issue'. If everything's nominal at normal 12-14V, then current limit can be raised to the device's normal operating current to check operation.
I've used simple variable voltage supplies for decades when troubleshooting or checking devices (mostly audio gear), but without the current limiter, the operator (me) becomes the detector/limiter, and may not be perceptive or quick-reacting enough to avoid damage. I'm getting lazy in my slower response time old age.
If you decide to roll your own LED landing lights, for example, a variable voltage/current supply could conceivably be used to experiment with various high power LEDs before buying a dedicated LED driver board.
As I mentioned earlier, the only thing I can think of that would be tougher to test this way would be electronics with 'switcher' power supplies. The switcher will try to draw as much current as it needs, to make full output, and may tend to be either full off (inadequate supply current) or full on, so the current/voltage monitoring technique may prove meaningless with some of those devices. Even with those devices, we can at least check that we have polarity correct and on the correct pin(s).
Charlie
On 11/14/2018 9:55 AM, Sebastien wrote:
Quote: | I have been thinking of getting one of these as well but a 30V 20A model. I have used one before but I'm not entirely sure how they work. What is the function on the amperage dial? In what situation would you set it lower than the maximum output of the power supply?
On Wed, Nov 14, 2018, 04:06 John Tipton <john(at)tiptonuk.eu (john(at)tiptonuk.eu) wrote:
Quote: | What’s wrong with a ‘cb’ type radio power supply, 13.8 volts, 3-5 amps, why do you need something giving variable volts/amps, are you really going to test your expensive electronics by playing around with varying these outputs —-
John
Sent from my iPad
----x--O--x----
Charlie
Rick Girard
-Brian
Charlie
Virus-free. www.avast.com [url=#m_-7689733828043912502_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Posted: Wed Nov 14, 2018 10:07 am Post subject: Cheap bench supply? |
Yes. You can turn the current down so that no matter the voltage, you only get a set amount of current.
----x--O--x----
Quote: | Thanks, to Richard, Earnest and Bob. Looks like I need to go ahead & pull the trigger. I'll report when it comes in. Charlie On 11/13/2018 7:47 PM, Richard Girard wrote:
Rick Girard
Charlie
MMiller
Posted: Wed Nov 14, 2018 10:11 am Post subject: Re: Cheap bench supply? |
Charlie, I bought two of these units back in June from a different Ebay vendor. The only issue I had was an intermittent connection in the line cord at P/S end of one unit. It uses a standard computer line cord, so I just replaced it with one I had laying around. It works as advertised and it’s a good value.
Posted: Wed Nov 14, 2018 10:58 am Post subject: Cheap bench supply? |
On 11/14/2018 12:11 PM, MMiller wrote:
Sounds good.
Thanks for the 'PIREP'; I've got one on the way.
Charlie
jimkale(at)roadrunner.com Guest
Posted: Wed Nov 14, 2018 2:00 pm Post subject: Cheap bench supply? |
I am careful about buying electronic equipment like battery chargers and power supplies.
The very inexpensive stuff Is built from inexpensive parts which may fail fairly quickly.
It this kind of equipment fails in the max voltage mode, it can FRY some very expensive equipment being powered or tested in short order. A battery charger that fails in an over voltage mode can COOK a very expensive battery quickly.
I have wondered the streets of some of the third world countries and seen some of the "SURPLUS" electronic parts that often go into cheap test equipment. This was a real eye opener experience.
alec(at)alecmyers.com Guest
Posted: Wed Nov 14, 2018 2:48 pm Post subject: Cheap bench supply? |
The current adjustment sets an upper bound on the current the unit will supply. If you try to draw more current than that, the output voltage falls far enough that the current stays at the limit you set.
You can use PSUs with a current limiting facility in either of two modes. Either constant voltage, which is what is normally used, or constant current mode. There are not many circuits that need a constant current drive, but I used to use one for charging NiCd batteries (in the olden days) where the current would be set at (say) 5x the one hour cell capacity and I could charge four or more cells in series. The terminal voltage would start low, and automatically rise as the cells charged.
Quote: | >In what situation would you set it lower than the maximum output of the power supply?
When you have a circuit that needs a constant current supply, or, as someone suggested, when you have a circuit which, should a fault develop, you want to limit the maximum power your supply can generate.
John
Sent from my iPad
----x--O--x----
Charlie
> Rick Girard
> On Tue, Nov 13, 2018 at 6:29 PM Brian Lester <brian.lester(at)gmail.com> wrote:
> -Brian
> On Tue, Nov 13, 2018 at 6:44 PM Charlie England <ceengland7(at)gmail.com> wrote:
> On Tue, Nov 13, 2018 at 5:18 PM Ernest Christley <echristley(at)att.net> wrote:
> Thanks,
> Charlie
Posted: Wed Nov 14, 2018 6:58 pm Post subject: Cheap bench supply? |
At 04:00 PM 11/14/2018, you wrote:
Quote: | --> AeroElectric-List message posted by: "jim" <jimkale(at)roadrunner.com>
I have wondered the streets of some of the third world countries and seen some of the "SURPLUS" electronic parts that often go into cheap test equipment. This was a real eye opener experience. |
I can't speak from any documentable source
but I believe your concerns are becoming
less significant if not non-existant.
The ability of industries to fabricate
and utilize perfectly acceptable parts
has been falling exponentially for some
time. The handling $COST$ of processing
sub-standard parts into products can
easily exceed the cost of 'good' parts.
Ergo, for the vast majority of examples
on the market, I've found that the offerings
are of good value. Out here in the
hinterlands of western Kansas, my
FIRST choice for on-line shopping is
eBay, not necessarily because it has
proven to be 'better' than any other
source . . . only adequate to my needs.
Vendors with high percentages of satisfactory
customers over hundreds if not thousands
of transactions have proven to be very
low if not zero risk.
