New Video
Rex Rodebush
PostPosted: Wed Nov 07, 2018 12:17 pm    Post subject: New Video Reply with quote
This is a flight up the James River in Missouri. Click on https://youtu.be/Uz4EOpVMYDk or go to Youtube and type in "Kolb flight up the James River."
gdhelton(at)gmail.com
PostPosted: Wed Nov 07, 2018 1:08 pm    Post subject: New Video Reply with quote
Beautiful country. A pleasant flight. Thank you, my flying is over for the year up here in Michigan, so thanks for the ride along.
George H.
Firestar, FS100, 2702 Hirth
14GDH
Mesick, Michigan
http://forums.matronics.com/viewtopic.php?p=484574#484574
west1m
PostPosted: Fri Nov 09, 2018 5:54 pm    Post subject: Re: New Video Reply with quote
Great fall flight. thanks!
As above, the flying is done here in Minnesota as well. I just ordered a full enclosure set for my Firefly from Kolb. Maybe that will let me get out a bit earlier next year.
West1m
Hastings, MN
lcottrell
PostPosted: Fri Nov 09, 2018 6:07 pm    Post subject: New Video Reply with quote
Your findings may be a bit different than mine, but I don't use the plastic part that goes around the cockpit. I found that it cut down on my speed by a lot and was just as comfortable with just the wrap around windscreen. It seemed to me that it made a lot of drag and cut my speed to 60 miles per hour max. Unless you have a heater it doesn't stay all that warmer. If you have a two stroke I can show you want I did to make a heater that seemed to work pretty well. Feet still got cold though. I just bought a "Chilly Vest", wrapped a scarf around my neck, and did just as well.
Larry
On Fri, Nov 9, 2018 at 6:56 PM west1m <west1m(at)hotmail.com (west1m(at)hotmail.com)> wrote:
--> Kolb-List message posted by: "west1m" <west1m(at)hotmail.com (west1m(at)hotmail.com)>
West1m
Hastings, MN
http://forums.matronics.com/viewtopic.php?p=484731#484731
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
WIKI -
west1m
PostPosted: Sat Nov 10, 2018 10:37 am    Post subject: Re: New Video Reply with quote
Larry, thanks for the insite. I just finished making a piece for behind the seat while waiting to hear from Kolb. I will have to try it out with just the windshield first before I mount the back and sides. Maybe that is all I need.
I do have pictures of a heat system for the rotax that someone (you?) posted in the past that I would use.
West1m
Hastings, MN
