Dual Battery Dual Alternator Power Distribution System
PostPosted: Mon Nov 05, 2018 1:51 pm    Post subject: Dual Battery Dual Alternator Power Distribution System Reply with quote
At 02:41 PM 11/5/2018, you wrote:
Thank you for making that point clear about no bus at risk for complete loss of power in the Z-14 design. I am no expert on the electrical systems and won't even claim a novice status but I do claim to be very logical and I could not see a total failure situation in the Z-14 as long as you had a cross feed engaged and you have not lost everything. That is the reason that I decided to go with the Z-14 for my plane and I don't think I will be disappointed. The reality is that it was not that difficult to understand or incorporate. Besides I like having the extra battery power for starting.
Keep in mind that normal ops are with the cross-feed
feature OPEN. This avoids having one alternator shut
down without a low-voltage annunciation.
Every bus (other than battery busses) has FOUR
sources of energy available for mitigation of
any single failure event.
It was the designer's mis-application of
"multiple feed busses" that set up a recipe
for failure in the N811HB accident
in California. That accident was a particular
disappointment . . . the builder attended
one of my seminars and had a copy of the book.
Neither he nor his professional assistant were
members of the List. Preventing the circumstance
that primed that accident was stone simple.
The 4th video on this page illustrates the
advantage powering the dual ignition system
from independent Z14 batteries
https://tinyurl.com/msfmldj
lwesterlund
PostPosted: Mon Nov 05, 2018 3:10 pm    Post subject: Re: Dual Battery Dual Alternator Power Distribution Sys Reply with quote
Thanks for the quick reply and the video.
I’d be curious to know what you recommend regarding an architecture that incorporates the Vertical Power system (or something like it) and p-mag ignitions.
Assuming you use the VPX as the main power distribution bus in Z-14, doesn’t it essentially become a potential single point of failure for all loads on that bus? I understand that the Pro version has two controllers and two internal buses, but if the entire box went up in smoke, or had to be pulled, it would kill everything downstream; the two batteries and the two alternators could no longer connect to the loads even with the cross connect capability.
What I penciled out was a way to take advantage of the VPX and dual feed avionics to allow you to still get power to all flight critical components. Kill any component, including the VPX, and you still have at least one alternator and one battery on-line.
It seems like a reasonable way to leverage the robust nature of the Z-14 design while availing oneself of the newest technology that allows one to monitor and control power real time. So back to the original question-what’s the best way to integrate the VPX into a dual bat/ dual alt system?
Lance
