Splice wires
rngurley(at)att.net
PostPosted: Fri Nov 02, 2018 7:14 am    Post subject: Splice wires Reply with quote
What is the proper technique for splicing two #14 wires to one #16 wire. Sorry for the newbie question. Thank you
PostPosted: Fri Nov 02, 2018 7:58 am    Post subject: Splice wires Reply with quote
At 10:09 AM 11/2/2018, you wrote:
--> AeroElectric-List message posted by: Dick Gurley <rngurley(at)att.net>
Lots of ways work just fine. you can use a crimped
butt splice, although you'd have to use a yellow
splice and double up one of the wires.
You can do a soldered lap-joint covered
in heat shrink.
But I'm curious as to the mixture
of wire sizes. What power do these wires carry and
what is the circuit protection for those wires?
rngurley(at)att.net
PostPosted: Fri Nov 02, 2018 11:02 am    Post subject: Splice wires Reply with quote
Thank you Bob -
The two wires come from a heated Garmin pitot tube system. Garmin twisted and soldered the two wires together at the factory. The Garmin G3X manual calls for 14 gauge wire for the length required (>21 feet). The manual also calls for a 20 amp fuse for power onto the control box. The max current draw is listed at 12 amps.
I measured the provided twisted and soldered wire to obtain a 12 gauge equivalent.
Where can I learn about a soldered lap joint with heat shrink
Than you again
Dick
On Nov 2, 2018, at 11:57 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: Dick Gurley <rngurley(at)att.net (rngurley(at)att.net)>
in heat shrink.
Bob . . . =================================== otstore.com matronics.com/contribution =================================== st">http://www.matronics.com/Navigator?AeroElectric-List =================================== cs.com =================================== om =================================== matronics.com/contribution ===================================
art(at)zemon.name
PostPosted: Fri Nov 02, 2018 8:48 pm    Post subject: Splice wires Reply with quote
On Fri, Nov 2, 2018 at 2:21 PM Dick Gurley <rngurley(at)att.net (rngurley(at)att.net)> wrote:
Dick,
I wrote it up with photos in my blog post Physical & Electrical Considerations when Mounting Avionics. That post also includes a link to Bob's shop notes on "Poor Man's Solder Sleeves" which have all of the detailed instructions that you will need.
Also see my photos near the bottom of my blog post Wiring Harness Installed because there are some splices with 1 wire coming into the splice and 2 wires going out the other side.
    -- Art Z.
https://CheerfulCurmudgeon.com/"Be kind, for everyone you meet is fighting a hard battle."
PostPosted: Fri Nov 02, 2018 10:02 pm    Post subject: Splice wires Reply with quote
At 11:59 AM 11/2/2018, you wrote:
Thank you Bob -
https://tinyurl.com/c5v2xvm
skywagon185(at)gmail.com
PostPosted: Sun Nov 04, 2018 11:06 am    Post subject: Splice wires Reply with quote
Art Z., amazing that you find the time to keep your well designed multifaceted blog up to date and handle all of your projects and interests. ...Bravo..!
On Fri, Nov 2, 2018 at 11:06 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Thank you Bob -
art(at)zemon.name
PostPosted: Sun Nov 04, 2018 7:23 pm    Post subject: Splice wires Reply with quote
Thanks and LOL. My cheat is that I am doing a blog instead of a formal builder's log.
    -- Art Z.
On Sun, Nov 4, 2018 at 1:22 PM skywagon185guy <skywagon185(at)gmail.com (skywagon185(at)gmail.com)> wrote:
markwheelermd(at)icloud.c
PostPosted: Sun Nov 04, 2018 8:48 pm    Post subject: Splice wires Reply with quote
Thanks Kirk. It’s been a PITA for both of us.
On Nov 4, 2018, at 7:22 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
-- Art Z.
-- https://CheerfulCurmudgeon.com/"Be kind, for everyone you meet is fighting a hard battle."
bob.verwey(at)gmail.com
PostPosted: Sun Nov 04, 2018 9:06 pm    Post subject: Splice wires Reply with quote
….and modest too!
You are a man amongst men, Art!
Best...Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
On Mon, 5 Nov 2018 at 05:28, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
    -- Art Z.
