Battery grounding
rsmith52
PostPosted: Mon Oct 01, 2018 7:13 am    Post subject: Battery grounding Reply with quote
I will be installing a 6AH auxillary battery due to dual Lightspeed ignitions and to keep the EFIS alive during starting. I assume that both batteries should be grounded at the same location on the firewall?
PostPosted: Mon Oct 01, 2018 8:47 am    Post subject: Battery grounding Reply with quote
yes, but not critical. any sound airframe ground
would suffice for the small battery . . . it doesn't
supply cranking currents.
