ogdenk
Posted: Fri Sep 28, 2018 6:55 am Post subject: Battery cable |
I'm curious where people run their main cable from the battery to the front of the plane. Through the tunnel? That seems like a pain and I would have to drill some holes in the spar carrythrough or risk interference with the pitch push tube, plus route around the other things in there like fuel and brake lines etc. I have some conduits run from the back up the sides of the fuselage but I have a lot of stuff to run through them and that is a fat cable coming from the battery.
Kent
#40710 ultra-slow build
bdgillespie215(at)gmail.c Guest
Posted: Fri Sep 28, 2018 7:06 am Post subject: Battery cable |
I ran mine up the left sidewall where it would penetrate the firewall near the relay. Most of the “sensitive” wires are on the right side wall.
Byron | Quote: | On Sep 28, 2018, at 10:53 AM, Kent Ogden <ogdenk(at)upstate.edu (ogdenk(at)upstate.edu)> wrote:
Kent
Posted: Fri Sep 28, 2018 7:28 am Post subject: Battery cable |
As you point out, the tunnel gets busy. The wires I have in the tunnel are limited to the few things that make such runs convenient:
- Three antennas (comm #1 & #2 and transponder). The comm antennas are mounted on the bottom of the tunnel, one on each side. This provides plenty of clearance to the push tube and allows easy access. Transponder is under the passenger seat. (Side note: ADS-B antenna is mounted aft of the baggage compartment along with the ADS-B receiver, connecting wire is in a side conduit. VOR/ILS antenna is in the right wingtip).
- Fuel pump.
- Audio lines to all four headsets.
- Flap wires.
- Both stick grip wires.
- Red cube wires.
Everything else is in conduit, three on each side of the plane. I ended up filling up five of the six conduit runs. If memory serves the #2 welding cable going from the two Master Solenoids mounded at the batteries go up to the starter solenoid on the left side. Both battery ground wires go up the right side. As most of us end up with a lot of stuff aft, more conduit is better than not enough.
Carl
| Quote: | On Sep 28, 2018, at 10:53 AM, Kent Ogden <ogdenk(at)upstate.edu> wrote:
Kent
Kelly McMullen
Posted: Fri Sep 28, 2018 7:49 am Post subject: Battery cable |
I would keep wires not called for by the plans out of the tunnel as much as possible. I only have transponder (near front of tunnel), fuel pump wires in the tunnel. This is a metal airframe. Absolutely zero need for a ground wire from batteries to panel. The only ground wires needed for noise reduction are those between panel mount items, audio panel and central grounding tabs on firewall. Any item that draws more than a couple amps is better grounded through the airframe. You don't have to believe me, that is summary of discussions on the Aero-Electric forum.
You have enough wires fore and aft for positive power, com antennas, ADS-B, autopilot servo(s), nav lights, strobes, etc.
| Quote: | | Sent from my IBM-360 main frame |
On Fri, Sep 28, 2018 at 8:31 AM Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
| Quote: | --> RV10-List message posted by: Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)>
- Fuel pump.
- Flap wires.
- Red cube wires.
Carl
> Kent
WIKI -
A&P/IA, EAA Tech Counselor
KCHD |
rjones560xl@gmail.com
Joined: 29 Jul 2015 Posts: 64 Location: Las Vegas, NV
Posted: Fri Sep 28, 2018 6:45 pm Post subject: Battery cable |
I put my EarthX ETX 900 on the engine side of the firewall. I have a 43 pound prop with spinner so weight and balance will likely work out fine. I did the computations using Vans factory aircraft as a starting point and it was close to a wash. I ran my starter cable back down the left side of the BPE oil pan and up and over the engine mount using adel clamps on the engine mount. The battery weighs about 5 pounds and the battery cable will be about 18” long. The starter cable is the longest. The Battery is on the lower right side of the firewall. Yes it is more expensive, but it is a lot lighter and I saved several pounds of #2 cable. They also last much longer and the discharge rate while parked is close to insignificant.
Robert Jones
On Sep 28, 2018, at 09:16, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | On 9/28/2018 10:53 AM, Kent Ogden wrote:
| Quote: | I'm curious where people run their main cable from the battery to the front of the plane. Through the tunnel? That seems like a pain and I would have to drill some holes in the spar carrythrough or risk interference with the pitch push tube, plus route around the other things in there like fuel and brake lines etc. I have some conduits run from the back up the sides of the fuselage but I have a lot of stuff to run through them and that is a fat cable coming from the battery.
Kent
Up the left side per the Electrical Kit plans.
I didn't buy the Electrical kit (most don't) but the plans for it are very useful in terms of wire routing and discovering some parts (custom cable supports and such) that are available from Vans. My electrical system looks nothing like that supported by the kit but some of the parts and particularly the fat cable route to the firewall are very useful in many designs.
www.avast.com
[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
_________________ Robert J Jones
702-521-1840 |
