CJ6A Collector Tank Drain Fitting
Ttail
PostPosted: Sun Jul 07, 2024 3:49 pm    Post subject: CJ6A Collector Tank Drain Fitting Reply with quote
CJ6A Fuel Collector drain fitting. If I remove the cylindrical fitting (with attached Hex nut) what sort of gasket lurks on the other side ? If anyone has an image of the inside or a part number etc I would appreciate it. There is Nothing in the parts or other CJ manuals on this.
End game is to fit a curtiss style Drain valve here.
Sean Trestrail
ttail[at]internode.on.net
Chuck Marshall
PostPosted: Thu Jul 18, 2024 12:20 pm    Post subject: Re: CJ6A Collector Tank Drain Fitting Reply with quote
This what I have Sean. We did have a small leak under the strap holding the header tank that was welded. It has been cleaned up and repainted with new fitting. I can send a better pic when I RTB next week.
 Filesize:  2.82 MB
 Viewed:  18784 Time(s)
Rhino
Ttail
PostPosted: Wed Mar 05, 2025 6:05 pm    Post subject: Re: CJ6A Collector Tank Drain Fitting Reply with quote
Finally got round to getting this done. SAF-AIR CAV-180 drain installed.
Sean Trestrail
