Rotax 912iS Electrical Charging System
cluros(at)gmail.com
PostPosted: Sat Sep 08, 2018 6:37 pm    Post subject: Rotax 912iS Electrical Charging System Reply with quote
This question is specifically in relation to the Rotax 912iS stock electrical system. Lane A and B voltages are rock steady at 14 V, but the volt sensor on the Dynon Skyview is seeing 13.5 - 13.7 V. The aircraft is wired exactly as per Rotax installation instructions and follows their wire size recommendations. I'm going to stick a voltmeter on the battery tomorrow and see what the actual voltage at the battery is while the engine is running but if it confirms the Dynon reading I'm concerned the battery is never going to be charged.
The strange thing is the Dynon Skyview default for this engine's voltage output has 13.5 in the middle of the green band. For a Lycoming or Continental I put the green band at 14-14.5
Is anyone here familiar with the 912iS? If this is how the system is designed, what are the implications for an Odyssey PC680 that spends most of it's waking life at 13.5 V?
Thank you all,
Sebastien
PostPosted: Sun Sep 09, 2018 8:54 am    Post subject: Rotax 912iS Electrical Charging System Reply with quote
An SVLA battery should be run at no less than 14.0
and no more that 14.8 with 14.4 being the nominal
"target". Anything below 14.0 has a high probability
of failing to top off the battery after a significant
discharge. This has nothing to do with the make/model
of the engine.
If true, that battery is seriously under-served for
charging.
Your proposal to investigate battery terminal
voltage while in flight is a good move. Keep in
mind just because a certain voltage is recorded
at one place in a system, it's not a sure bet
that the same voltage will be recorded elsewhere
even tho both points are connected with copper
pathways. There are subtle but significant voltage
drops in system wiring. Further, if the readings
are taken with two different instruments, it's
possible that they may not be calibrated to the
same accuracy.
Irrespective of engine, the voltage regulator's
prime directive is TAKE CARE OF A BATTERY. Given
that there's a lot of copper monkey-motion between
the regulator and battery, the regulator's electronics
can only ASSUME that it knows what battery voltage
is.
For SVLA batteries, voltage in cruising flight with
a fully charged battery should be in the 14.2 to
14.6 range. If the alternator is off for any
reason, the battery voltage will fall quickly to
something under 13.0 volts. when the battery falls
to 11.0 volts, it has probably less than 5% of
it's maximum capacity remaining.
