Ground power question
ogdenk
PostPosted: Thu Aug 30, 2018 10:53 am    Post subject: Ground power question Reply with quote
I have added the ground power connector with overvoltage protection to my RV-10 build per the instructions at
http://www.aeroelectric.com/articles/grndpwr.pdf
As I look at the circuit, I wonder if the contactor will stay closed after being energized if there is a charged battery. Why won't current flow back through the contactor and keep the coil energized if the ground power is removed, there's no rectifier to prevent that?
I don't have a battery in my plane yet so I haven't tested this out.
Kent
<![endif]--> <![endif]-->
PostPosted: Thu Aug 30, 2018 11:27 am    Post subject: Ground power question Reply with quote
You are correct . . . which is why there is an
GND PWR annunciator light and crew controlled
switch.
