ADSB Antenna
erich weaver
PostPosted: Sat Aug 18, 2018 3:11 pm    Post subject: ADSB Antenna Reply with quote
Greetings
My uAvionix Echo ADSB unit came with a single transmit/receive pole style antenna. It receives on both 978 and 1080 MHz while transmitting on 978 MHz. I would like to replace it with a blade style antenna to be a bit more robust. Looking on the Delta Pop antenna website, I see an ADSB blade antenna for 978 MHz. Will that be sufficient to receive on 1080 MHz as well?
Erich
donvansanten(at)gmail.com
PostPosted: Sat Aug 18, 2018 3:25 pm    Post subject: ADSB Antenna Reply with quote
The Delta Pop antenna works fine. I use two, one for the transponder/ADSB out and one for the ADSB dual band in. Have used them for 2 tears with two different systems and they have been flauless.
On Aug 18, 2018 16:16, "erich weaver" <erich.weaver(at)aecom.com (erich.weaver(at)aecom.com)> wrote:
--> AeroElectric-List message posted by: "erich weaver" <erich.weaver(at)aecom.com (erich.weaver(at)aecom.com)>
Greetings
Erich
http://forums.matronics.com/viewtopic.php?p=482524#482524
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
          -Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
