damiller47
Posted: Sun Jul 01, 2018 6:44 am Post subject: TR-1 IO-240 Prince prop Spinner crack |
N660C, OC's plane, has been cracking spinners. Do any of you more experienced folks have any idea what may cause this?
110.33 KB |
8298 Time(s) |
_________________ Danny Miller
EAA Lifetime 647062
Aerospace Engineer
Technical Counselor
Flight Advisor
A&P
President
EAA Chapter 186
http://eaa186.org/ |
ftyoder(at)yoderbuilt.com Guest
Posted: Sun Jul 01, 2018 8:22 am Post subject: TR-1 IO-240 Prince prop Spinner crack |
What spinner is on the plane? The original kit came with a fiberglass
spinner. I believe OC was using a Prince prop which I am using but I changed
to an aluminum spinner with a forward bulkhead and have had no problem. The
original FG spinner did not have a forward bulkhead and would go into
vibration once in awhile which was irritating but it didn't crack.
damiller47
Posted: Sun Jul 01, 2018 10:38 am Post subject: Re: TR-1 IO-240 Prince prop Spinner crack |
The FG spinner cracked so I put on the aluminum one pictured but it had no forward bulkhead. Any idea where I can get another one ... with the forward bulkhead?
EAA Lifetime 647062
Aerospace Engineer
Technical Counselor
Flight Advisor
A&P
President
EAA Chapter 186
Posted: Sun Jul 01, 2018 11:17 am Post subject: TR-1 IO-240 Prince prop Spinner crack |
I ordered mine from Aircraft Spruce, you need to give them the prop hub
thickness.
