		rwstracy(at)gmail.com Guest
				 Posted: Thu Aug 09, 2018 2:57 pm    Post subject: RV-8 Wing tank removal |
				Working on the takeoff damage to the RV-8 and need to remove the tank for access and to repair the tank damage.  I’ve removed all the screws around the perimeter of the tank and the three [url=x-apple-data-detectors://0]3/16[/url]” bolts at the root into the spar web. .  That’s all I recall holding on the tank but it refuses to budge more than maybe .03” away from its position.
 Are there any other fasteners holding the tank on?  I’m in CO away from my plans.  Any ideas on tank removal if that’s not the problem?
 Thanks for any info or suggestions,
 Tracy Crook
  |  | - The Matronics RV8-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		bifft(at)xmission.com Guest
				 Posted: Thu Aug 09, 2018 3:12 pm    Post subject: RV-8 Wing tank removal |
				On Thu, 9 Aug 2018, Tracy Crook wrote:
  	  | Quote: | 	 		   Working on the takeoff damage to the RV-8 and need to remove the tank
 around the perimeter of the tank and the three 3/16” bolts at the root
   There are about 21 3/16" bolts in the spar web going into the "z-angles"
 on the back of the tank.  If you only removed three at the root you left
 most of them in.  The rest can be removed through the wing access holes on
 the bottom.  Many are in the next rib bay over from the access hole, so
 use a mirror and a flashlight to check that you got them all.  There are
 three in pretty much every rib bay behind the tank, except where the wing
 walk is.
   Other than that when I removed a tank to fix a fuel leak, it took a
 harder pull than I was expecting to pop the skin dimples out.
   Brian Huffaker, DSWL (bifft(at)xmission.com)
   RV-8A 80091  Test flying
				 Posted: Thu Aug 09, 2018 3:15 pm    Post subject: RV-8 Wing tank removal |
				Yes - many more 3/16” bolts holding the Z braces to the spar.
 Access them via the bottom inspection plates.
 Carl
 On Aug 9, 2018, at 6:15 PM, Tracy Crook <rwstracy(at)gmail.com (rwstracy(at)gmail.com)> wrote:
 Tracy Crook
		rnewman(at)tcwtech.com Guest
				 Posted: Thu Aug 09, 2018 3:21 pm    Post subject: RV-8 Wing tank removal |
				There are like 12 or 15 bolts AN-3 through the back of the spar and into z brackets on the back of the tank.   All accessed through the inspection hatches.
 Bob NewmanTCW Technologies, LLC
 610-928-3420
 Working on the takeoff damage to the RV-8 and need to remove the tank for access and to repair the tank damage.  I’ve removed all the screws around the perimeter of the tank and the three[url=x-apple-data-detectors://0]3/16[/url]” bolts at the root into the spar web. .  That’s all I recall holding on the tank but it refuses to budge more than maybe .03” away from its position.
 Tracy Crook
		ceengland7(at)gmail.com Guest
				 Posted: Thu Aug 09, 2018 4:13 pm    Post subject: RV-8 Wing tank removal |
				Hey Tracy,
        Same tank as the -7, AFAIK. The z brackets are behind every rib,       if memory serves. I think I can email you that page from the -7       plans, if you want.
        You can slip stuff like old credit cards or other thin  items       between the back edge of the tank & the spar to lift the       dimples prior to removing the tank. I've pulled the tanks on the       -4 several times. I usually pull out the root end slightly first,       using a wedge between the nose attach angles. Then, if needed, I       wedge something in the slight V between the other end of the tank       skin and the wing leading edge skin, and push the root end back       aft. This will shift the tank inboard and move the outboard end       forward slightly. Makes the rest of the removal go easier for me.
        Charlie
        On 8/9/2018 6:21 PM, Tcwtech wrote:
       	  | Quote: | 	 		                There are like 12 or 15 bolts AN-3 through the back of the spar       and into z brackets on the back of the tank.   All accessed       through the inspection hatches.
          Bob Newman           TCW Technologies, LLC
            610-928-3420
                  Tracy Crook
      	           		Virus-free. www.avast.com 		 	 [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
				 Posted: Fri Aug 10, 2018 4:53 am    Post subject: RV-8 Wing tank removal |
				Thank you guys.  Ah, the things you forget after 17 years (holy 💩, been that long?).
 I had recently pulled a tank on the -4 which doesn’t have the braces.  I should be able to get it from this info but thanks for offer of the plans Charlie.
 A copy of RV8 plans showing PN of left forward & bottom fwd. fuse parts would be handy if anyone has it scanned. Will be ready to order parts soon.
 Tracy Crook
 Sent from my iPad
 On Aug 9, 2018, at 18:14, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
  	  | Quote: | 	 		                     Hey Tracy,
        Charlie
            610-928-3420
                  Tracy Crook
				 Posted: Fri Aug 10, 2018 6:28 am    Post subject: RV-8 Wing tank removal |
				It's not as good as having the paper       plans to spread out in front of you, but you can get a thumb drive       containing the entire manual from Van's for about $10. Find a       laptop & copy it to the cloud, & copy back to your ipad.
        I'll check with Andy to see if he has a 'soft' copy, and email       those pages to you if he does.
        Charlie
        On 8/10/2018 7:52 AM, Tracy Crook wrote:
       	  | Quote: | 	 		                Thank you         guys.  Ah, the things you forget after 17 years (holy 💩,       been that long?).
          Tracy Crook
              Sent from my iPad
               	  | Quote: | 	 		                                                   Hey Tracy,
                    Charlie
                        610-928-3420
                              Tracy Crook
				 Posted: Fri Aug 10, 2018 6:47 am    Post subject: RV-8 Wing tank removal |
				No joy on the soft copy, but he's built/rebuilt several -8s. Want me to see
 if he has an extra set of printed plans he'd sell, if no one can send you a
 pdf of those pages?
 On Fri, Aug 10, 2018 at 9:21 AM, Charlie England <ceengland7(at)gmail.com>
 wrote:
 [quote] It's not as good as having the paper plans to spread out in front of you,
				 Posted: Fri Aug 10, 2018 10:59 am    Post subject: RV-8 Wing tank removal |
				Thanks Charlie.  The thumb drive is a perfect solution.  It will be here by the time I need it.
 Tracy
 [quote] On Aug 10, 2018, at 08:46, Charlie England <ceengland7(at)gmail.com> wrote:
  No joy on the soft copy, but he's built/rebuilt several -8s. Want me to see if he has an extra set of printed plans he'd sell, if no one can send you a pdf of those pages?
 > On Fri, Aug 10, 2018 at 9:21 AM, Charlie England <ceengland7(at)gmail.com> wrote:
 > Charlie
 >> Tracy Crook
 >> Sent from my iPad
 >> On Aug 9, 2018, at 18:14, Charlie England <ceengland7(at)gmail.com> wrote:
 >>> Hey Tracy,
