avdilger(at)yahoo.com Guest
				 Posted: Tue Jul 31, 2018 11:50 am    Post subject: RV8-List Digest: 3 Msgs - 07/30/18 |
				Ouch….thats a bummer…..no small task
  	  | Quote: | 	 		   On Jul 30, 2018, at 23:42, RV8-List Digest Server <rv8-list(at)matronics.com> wrote:
  Today's complete RV8-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the RV8-List Digest and can be viewed with a generic text editor
  HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-07-30&Archive=RV8
  Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-07-30&Archive=RV8
                            RV8-List Digest Archive
                      Total Messages Posted Mon 07/30/18: 3
  Today's Message Index:
      1. 04:53 AM - Re: Matt's repair  (Bill Settle)
      2. 11:43 AM - Re: Matt's repair  (Tracy Crook)
      3. 02:49 PM - Re: Matt's repair  (John Miller)
  ________________________________  Message 1  _____________________________________
  Time: 04:53:49 AM PST US
  Subject: Re: Matt's repair
  Tracy,
  Sorry to hear about your misfortune.=C2- Matt wound up replacing his fuse
  lage.=C2- Not a small nor inexpensive endeavor.=C2-=C2-
  Details can be found here....
  http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273&c
  ategory=9041
  Good luck and let us know what you decide.
  Bill Settle=C2-
  "Experience and common sense cannot be replaced with policy and procedures.
  =C2- - R.L. Nuckolls III
  To: rv8-list(at)matronics.com
  Sent: Sunday, July 29, 2018 2:25 PM
  I recently had an incident on takeoff (strong gust forced me off side of ru
  nway) and left gear attach point was forced up into the fuselage when it hi
  t the edge of an intersecting taxiway. It caused the exact same airframe da
  mage that Matt had on his RV-8 in landing incident.
  I never heard how the repair went or if it was successful and how hard was
  the repair job.=C2- I=99d love to hear something from Matt or other
  s on how it went.
  Tracy Crook
  Sent from my iPad
 >> On Jun 26, 2018, at 11:57, Brian Huffaker <bifft(at)xmission.com> wrote:
 >> On Tue, 26 Jun 2018, Al Dilger wrote:
 >> Been wondering about a few RV issues.
 >> 1=Does anyone know of an accurate fuel measuring device for RV
  =99s? (RV8A) I have Garmin G3X Touch with the Stewart Warner floats.
 >> Because the =9Cthrow=9D (depth of tank) is relatively short
  the gauges read 16 gal when full (21g) and stay there until there is about
  13g left, aside from that they are pretty accurate.
 >> Im thinking that a dipstick type of gauge attached to the bottom of the
  fuel cap could be worked out..Any thoughts???
 > A dipstick would have the same problem in the opposite direction, reading
 > nothing for the last few gallons.=C2- Also you couldn't use it in fligh
  t.
 > Would be easy enough to calibrate one starting from an empty tank.
 >> 2= I would like to see an improvement to the canopy rollers, it seems
 >> to me that a hard rubber wheel would work better.
 > Would be an easy change to make, but don't see why rubber wheels would be
 > an improvement.
 >> 3= I remember when building I had seen a mod to allow the pilot seat
 >> back to move more rearward (My seat back sits up too straight) wonder if
 >> there is a more simple way to accommodate that then changing and
 >> modifying
 >> =C2- =C2- the center support bar.
 > That would be the "tall pilot option" that Van's sells, they say it is
 > for 6'6" and up, I'm only 6'4" and have it.=C2- Have to duck to close t
  he
 > canopy if wearing headset.=C2- It is just a different center bar with t
  he
 > main support further back.=C2- The extruded angle that forms the sides
  of the
 > seatback are also left longer.
 > If you have short legs, you could move the seatback hinge forward to
 > get a steeper angle and use the standard center bar.=C2- This would mea
  n less
 > leg room, need a different size/shape seat cushion.=C2- You wouldn't ha
  ve as
 > bit a flat space before the slope up at the front of the seat.
 > Brian Huffaker, DSWL (bifft(at)xmission.com)
 > RV-8A N609HZ in test period
  S -
  WIKI -
  =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin.
  ________________________________  Message 2  _____________________________________
  Time: 11:43:36 AM PST US
  Thanks for the link Bill, just what I needed.
  As Matt noted, the RV-8 gear will take even hard landing loads but not strai
  ght up vertical loads.  My damage was almost exactly what Matt's was except m
  y gear leg (same as Matt's) was not bent and I had no wing damage except for
  the wing tank rib.  The wheel pant shattered on impact with the edge of the
  taxiway and part of it fell off somewhere during my flight around the patte
  rn.  I heard it flopping around then stop.
  The exciting part was the fuel spraying into the cabin from the damaged tank
  rib.  As a side note, I was glad I had plumbed the fuel line in rubber hose
  instead of aluminum. It probably would have broken off like the aluminum ve
  nt line did and I=99d have never made it around to land.
  I=99m in the process of drilling out skin rivets and exposing the stru
  cture and while it=99s not going to be a picnic, I=99m going to a
  t least give repairing the fuselage a try.
  Tracy Crook
 > On Jul 30, 2018, at 05:53, Bill Settle <billsettle(at)bellsouth.net> wrote:
 > Tracy,
 > Sorry to hear about your misfortune.  Matt wound up replacing his fuselage
  .  Not a small nor inexpensive endeavor.
  category=9041
 > Bill Settle
 >  - R.L. Nuckolls III
 > From: Tracy Crook <rwstracy(at)gmail.com>
  unway) and left gear attach point was forced up into the fuselage when it hi
  t the edge of an intersecting taxiway. It caused the exact same airframe dam
  the repair job.  I=99d love to hear something from Matt or others on h
  ow it went.
 > Tracy Crook
 > Sent from my iPad
  ________________________________  Message 3  _____________________________________
  Time: 02:49:26 PM PST US
  Tracy,
  Please post some pictures for us when you can.
  grumpy
  N82W (in the paint shop now!)
  straight up vertical loads.  My damage was almost exactly what Matt's
  was except my gear leg (same as Matt's) was not bent and I had no wing
  damage except for the wing tank rib.  The wheel pant shattered on impact
  with the edge of the taxiway and part of it fell off somewhere during my
  flight around the pattern.  I heard it flopping around then stop.
  damaged tank rib.  As a side note, I was glad I had plumbed the fuel
  line in rubber hose instead of aluminum. It probably would have broken
  off like the aluminum vent line did and I=99d have never made it
  around to land.
  the structure and while it=99s not going to be a picnic, I=99m
  going to at least give repairing the fuselage a try.
 > Tracy Crook
  <mailto:billsettle(at)bellsouth.net>> wrote:
 >> Tracy,
  fuselage.  Not a small nor inexpensive endeavor.
  category=9041
  <http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273
  &category=9041>
 >> Bill Settle
  procedures."
 >>  - R.L. Nuckolls III
 >> From: Tracy Crook <rwstracy(at)gmail.com <mailto:rwstracy(at)gmail.com>>
 >> To: rv8-list(at)matronics.com <mailto:rv8-list(at)matronics.com>
  of runway) and left gear attach point was forced up into the fuselage
  when it hit the edge of an intersecting taxiway. It caused the exact
  same airframe damage that Matt had on his RV-8 in landing incident.
  hard was the repair job.  I=99d love to hear something from Matt
  or others on how it went.
 >> Tracy Crook
 >> Sent from my iPad
  <mailto:bifft(at)xmission.com>> wrote:
  |  | - The Matronics RV8-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
