Can You PLEASE help Me Find a CHINT NP4 Switch (or equival
PostPosted: Sat Jul 28, 2018 11:28 am    Post subject: Can You PLEASE help Me Find a CHINT NP4 Switch (or equival Reply with quote
At 02:08 PM 7/28/2018, you wrote:
Sorry for the slightly off topic post (however this is for a machine installed inside my airplane hangar).
I am looking for a pushbutton switch to replace the broken one on my hydraulic lift.¬
It's a push button momentary contact on single pole single throw switch.¬ The diameter of the hole in the panel is 0.894 inches / 22.72 MM.¬
The switch that broke is labeled CHNT NP4 and it has other numbers on it such as GB140 48.5 and it's a 10 amp switch.¬ ¬
It is a switch that you push and hold in the button and then a relay closes to energize the electric motor that moves the hydraulic pump.
Again, sorry about the off-topic post however I've spent 30 minutes on the Google¬ with no success but I'm sure there's a guy on this forum that will recognize this switch immediately and know exactly where to find one (or one that will work).
Thanks!!!¬
Bill Hunter
There is nothing electrically special about this
switch other than the fact that it's normally open.
You probably want to get the door operable ASAP
so go to a hardware store and get ANY normally open
P.B. Here's one example at Lowes.
https://goo.gl/66gez5
Wire it into place temporarily . . . mgiht even let it
dangle on the wires wrapped with tape to keep the
electrons from tunning onto the floor.
Then order one of these:
https://goo.gl/pTKXPT
It will directly replace the switch that's broken
and will be delivered to your door in a few days
for free.
