Woodcomp Propeller Overhaul
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
lsvance54
PostPosted: Sun Jul 15, 2018 1:03 pm    Post subject: Woodcomp Propeller Overhaul Reply with quote
I just completed the LSRM-A repairman course and found a Service Bulletin on the Woodcomp Propeller that I did not previously know about.
Apparently, my 2006 Allegro 2000 should have been grounded for a propeller overhaul as of 2012. The Woodcomp Klassic 160 has a 6 year/ 950 hour TBO.
Anyone have a U.S. source for overhaul? Is there an alternate prop that has a better TBO or longer age limit?
[/list]
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
Scott
N25017
Brian Carpenter
PostPosted: Sun Jul 15, 2018 1:19 pm    Post subject: Woodcomp Propeller Overhaul Reply with quote
I would encourage you to communicate with Doug at Allegro USA.. He would be the one that would know how to respond to this question.
Sent from my Brian's
iPhone
[/list]
Scott
N25017
http://forums.matronics.com/viewtopic.php?p=481651#481651
BRIAN N3081X
N456TS
PostPosted: Mon Jul 16, 2018 4:12 pm    Post subject: Re: Woodcomp Propeller Overhaul Reply with quote
[/list]
As you know, you're NOT limited to specific age requirements. It can be evaluated on-condition and signed off by you.
N456TS
N456TS
PostPosted: Mon Jul 16, 2018 5:58 pm    Post subject: Re: Woodcomp Propeller Overhaul Reply with quote
lsvance54 wrote:
> Sir,
> I have a SLSA Allegro 2000. If I were flying experimental, I believe you
> are correct. I could then evaluate and sign off.
> Had a conversation with Light Sport Guru recently from OKC (FAA). First
> thing he asked me was why I'm not already Experimental!
> How am I NOT age limited as an SLSA?
> Thanks!
> L. Scott Vance
I refer you to the Willette letter. As you might know, the FAA legal
department interprets their regulations. This interpretation become
the FAA's official position on a subject unless the FAA is taken to
court and a judge disagrees.
The short of it is that the FAA is always above the manufacturer. The manufacturer can't over-extend their authority. They also can't stop you from using alternative methods acceptable to the administrator, such as on-condition inspection. I've attached the letter.
Doug will also refer you to the same.
You can perform an on-condition inspection on an S-LSA and an E-LSA. This is a practice acceptable to the administrator and is absolutely the norm. I've worked on several Allegros. I don't believe any of them had replaced their prop simply due to the bulletin.
Best regards,
Bradley Pearce
willette-dodgecenteraviation-legal-interpretation.pdf
FAA legal letter
 Filename:  willette-dodgecenteraviation-legal-interpretation.pdf
 Filesize:  91.37 KB
 Downloaded:  1243 Time(s)
N456TS
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
