art(at)zemon.name Guest
Posted: Tue Jul 03, 2018 10:32 am Post subject: How to Wire My Alternator |
Quick follow-up for y'all. I fired up the engine a couple of weeks ago or so and did not see any output from the new B&C alternator. When I debugged it, I found a blown fuse on the field wire. This morning, I ran the engine and the alternator worked like a champ, pumping out about 15 amps.
Thanks for the advice.
-- Art Z.
https://CheerfulCurmudgeon.com/"We do not see the world as it is. We see the world as we are."
265.29 KB |
3232 Time(s) |
255.33 KB |
3232 Time(s) |
Posted: Tue Jul 03, 2018 3:44 pm Post subject: How to Wire My Alternator |
At 01:31 PM 7/3/2018, you wrote:
| Quote: | | Quick follow-up for y'all. I fired up the engine a couple of weeks ago or so and did not see any output from the new B&C alternator. When I debugged it, I found a blown fuse on the field wire. This morning, I ran the engine and the alternator worked like a champ, pumping out about 15 amps. |
What kind of ov protection? If you're
using a B&C regulator or one of the
several crowbar ov protection modules,
upstream power for the field should be
on a PANEL MOUNTED BREAKER . . . not
a fuse.
Posted: Tue Jul 03, 2018 7:57 pm Post subject: How to Wire My Alternator |
On Tue, Jul 3, 2018 at 6:58 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
a fuse.
You are absolutely right, of course. I discovered that a month ago, after I hooked everything up according to Z-13 and then actually read the installation instructions for the B&C voltage regulator. Installing the breaker is high on my to-do list.
Thanks for the eagle-eye.
-- Art Z.
