Z-14 Question (OOPS!)
PostPosted: Sat Jun 30, 2018 8:04 am    Post subject: Z-14 Question (OOPS!) Reply with quote
Having recited the legacy philosophy I'll
note that all three of the vehicles in my
driveway ranging from 87GMC to 2006KIA
ALL connect the b-lead directly to the battery . . .
not even fusible links.
Not true. My 87GMC alternator wire goes
directly to battery(+) but it's only about
18" long and hangs out in the air.
The 98SAT battery(+) does have a fusible link at the
starter solenoid.
The 06KIA has an MANL style fuse right at
the battery(+) terminal.
In both cases, b-lead protection is at the
BATTERY end of the b-lead.
Rocketman1988
PostPosted: Sun Jul 01, 2018 5:22 am    Post subject: Re: Z-14 Question (OOPS!) Reply with quote
Bob,
Along these same lines, I will have to run two battery buss leads from the aft batteries to the forward busses...about 8.5'.
Using the logic presented here, I need to install a current limiter in each battery lead, near the batteries...
Does this sound like a good plan, or am I missing something?
