digidocs
Posted: Fri Jun 29, 2018 8:22 am Post subject: Any success with sound reduction? |
Hi list,
Has anyone had success with sound reduction in the cockpit?
At the moment, I'm experiencing 96-97dBA in cruise and 100+dBA at high power. I've got good headsets, but I'd like to do better than this. I am willing to spend a little money and weight.
At the moment, there's only carpet on the front and rear passenger floors. All other surfaces are painted metal/fiberglass. It seems like there's room for improvement, but I would love to hear the experience of anyone who's been there before.
Thanks!
David
Tim Olson
Posted: Fri Jun 29, 2018 10:25 am Post subject: Any success with sound reduction? |
Add some sort of fabric headliner and sidewall covering, for starters to reduce the echo chamber.
Tim
| Quote: | On Jun 29, 2018, at 11:19 AM, David Carr <junk(at)dcarr.org> wrote:
Hi list,
Thanks!
David
Kelly McMullen
Posted: Fri Jun 29, 2018 6:58 pm Post subject: Any success with sound reduction? |
I've taken no measurements, but I put super sound insulation http://www.aircraftspruce.com/catalog/appages/supersoundproofsheet.php
under the floorboards in front and rear footwells, up the sides of fuselage and under baggage compartment floor, as well as in the doors.
Did not use it on the firewall, went with higher temp material.
| Quote: | | Sent from my IBM-360 main frame |
On Fri, Jun 29, 2018 at 11:23 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Tim
> On Jun 29, 2018, at 11:19 AM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
> Hi list,
> Thanks!
> David
WIKI -
A&P/IA, EAA Tech Counselor
KCHD |
Lenny Iszak
Posted: Fri Jun 29, 2018 7:22 pm Post subject: Any success with sound reduction? |
A few years ago there was a guy with a boombox in a cooler at OSH. He closed that cooler and it got dead quiet. It was impressive. It cost a 1AU for the whole plane. I installed it under the floor boards, but then realized how flammable this stuff is. I’d rather take the noise than the toxic fumes. I would love to remove them all, but it’s not so easy now.
With a pair of Bose A20 (or Lightspeed Zulus) headsets you shouldn’t hear much of it…
Lenny
| Quote: | On Jun 29, 2018, at 12:19 PM, David Carr <junk(at)dcarr.org> wrote:
Hi list,
Thanks!
David
_________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
Kelly McMullen
Posted: Fri Jun 29, 2018 8:11 pm Post subject: Any success with sound reduction? |
That is why I chose the material I did. From catalog: Has fire retardant qualities and meets FAR 25.853a Appendix F, Pt1.
On Fri, Jun 29, 2018 at 8:20 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
| Quote: | --> RV10-List message posted by: Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
Lenny
> On Jun 29, 2018, at 12:19 PM, David Carr <junk(at)dcarr.org (junk(at)dcarr.org)> wrote:
> Hi list,
> Thanks!
> David
WIKI -
KCHD |
digidocs
Posted: Fri Jun 29, 2018 11:58 pm Post subject: Any success with sound reduction? |
Hi Kelly,
What did you use on the firewall?
David
On Fri, Jun 29, 2018 at 9:56 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
| Quote: | I've taken no measurements, but I put super sound insulation http://www.aircraftspruce.com/catalog/appages/supersoundproofsheet.php
Tim
> Hi list,
> Thanks!
> David
WIKI -
Kellym
Posted: Sat Jun 30, 2018 4:16 am Post subject: Any success with sound reduction? |
IIRC it was one of the fiberfrax varieties. No sound qualities.
On 6/30/2018 12:56 AM, David Carr wrote:
| Quote: | Hi Kelly,
David
<http://www.aircraftspruce.com/catalog/appages/supersoundproofsheet.php>
Tim
> On Jun 29, 2018, at 11:19 AM, David Carr <junk(at)dcarr.org <mailto:junk(at)dcarr.org>> wrote:
> Hi list,
> Thanks!
> David
<http://www.matronics.com/>Navigator?RV10-List
<http://forums.matronics.com>
WIKI -
<http://wiki.matronics.com>
<http://www.matronics.com/>contribution
KCHD |
