Alternator Noise When Touching Metal Airframe Grounds
rnjcurtis(at)charter.net
PostPosted: Tue Jun 19, 2018 10:28 am    Post subject: Alternator Noise When Touching Metal Airframe Grounds Reply with quote
Is the noise still present when the ANR is turned off?
Roger
At 09:36 AM 6/19/2018, you wrote:
Good suggestion, thanks. So far all 4 lemo sets are the same. I have a dual plug version of the same bose to try, and can do that and report back
Hmmmm . . . not sure I've got an accurate image
of the differences between 'lemo' and 'dual plug'.
Does this described the connectors at the end
of the headset cord . . . single mulit-pin as opposed
to "Y" plugs?
To be significant, the test headset needs to
  be a generic, non-electronic . . . but go
ahead and try the dual-plug Bose X too.
