Sequence for bringing alternators on line.
PostPosted: Wed Jun 13, 2018 5:23 am    Post subject: Sequence for bringing alternators on line. Reply with quote
At 09:07 PM 6/12/2018, you wrote:
The two relays and starter contactor should all have diodes just like the battery contactor does. Connect banded end of diodes to positive.
Can the start switch handle the start contactor coil current? Or is the E-123 Relay necessary?
The ACS/Bendix/Gerdes key switch will handle
the automotive starter contacter that's fitted
with a supression diode. Many (like the B&C
S702) have the diode built in. If in doubt,
install a second one . . . two are better
than none. The buffer relay is not necessary
but doesn't hurt anything . . . if left in
add the diode to it too as Joe suggests.
