B&C switches
blues750
PostPosted: Tue May 22, 2018 5:09 pm    Post subject: B&C switches Reply with quote
Preparing to wire up a small hydraulic pump to operate amphibious float wheels.
Spec sheet on the parker pump unit indicates to use a DPDT center off switch
rated for up to 20A DC at 12V. Looking at B&C S700 series -1. My concern is that the switch is rated for up to 15 VAC. Equivalent, or should I continue my search for a switch? If so, any pointers appreciated. Wink
Dave (the novice electrician/soon to be float flyer)
P.S.
The tech graph for current draw of the pump at 12 VDC and set pressure of 300 psi is approx. 13 Amps.
