Posted: Fri May 25, 2018 6:07 am Post subject: WIFI Repeater/Booster Options For My Remote Steel Hangar?? |
Quote: |
My steel hangar is about 50 feet away and there is cement and asphalt over the ground between the house and the hangar so to dig down and install a CAT 5 cable run out to the hangar is not a fun option.
Are there any WIFI extender options available to get WIFI out to the hangar? |
I presume you have AC power in the hangar. I'm also
hoping that the feeder comes off a breaker in your
house. If so, you might consider a product like
this:
https://goo.gl/srUq55
Asoka is not the only supplier of such devices.
These are power line connected cat5 transceivers.
Put one in the house with a jumper to your
router and the second in the hangar.
I've been using these things around here
for several years . . . saved me a lot
of time/effort stringing wire. I've got
a couple of surplus devices I could
send you to experiment with.
But if your hangar doesn't get ac power from
the house distribution panel . . . all bets
are off.
