Z 16 OVP fuselink question (CORRECTION)
PostPosted: Fri May 04, 2018 3:35 pm    Post subject: Z 16 OVP fuselink question (CORRECTION) Reply with quote
The redirection link didn't capture the whole
page . . . here's a 'fix' . . .
Fusible links in vehicles are expected to protect
major feeders of a distribution system against
hard faults . . . generally experienced only during
major disassembly of the vehicle. By hard fault,
were talking many times hundreds to thousands of
amps supplied by a battery . . . not the soft
fault precipitated by a failing appliance.
https://goo.gl/up9oNB
wdaniell.longport(at)gmai
PostPosted: Tue May 08, 2018 7:02 am    Post subject: Z 16 OVP fuselink question (CORRECTION) Reply with quote
So continuing this theme on z16 can you explain why the alt has a 16 awg fuse link and the buss doesnt?
Will
On Fri, May 4, 2018, 18:40 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
ceengland7(at)gmail.com
PostPosted: Tue May 08, 2018 8:00 am    Post subject: Z 16 OVP fuselink question (CORRECTION) Reply with quote
The link protects the 12awg from the battery, in case of a hard fault on that line. (Think about faults under the cowl, where you'd never see/smell them in operation.)The feed to the main bus is protected from the battery by the master contactor, with the expectation that the pilot would detect the fault and manually turn off the master. Common FAA-accepted practice in certified planes.
On Tue, May 8, 2018 at 9:52 AM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will
PostPosted: Tue May 08, 2018 9:14 am    Post subject: Z 16 OVP fuselink question (CORRECTION) Reply with quote
Charlie thanks
So it wouldn't be "wrong" to put a fuselink in the line to the buss?
WIll
William Daniell
LONGPORT
+57 310 295 0744
On Tue, May 8, 2018 at 10:59 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Will
PostPosted: Tue May 08, 2018 12:53 pm    Post subject: Z 16 OVP fuselink question (CORRECTION) Reply with quote
At 12:13 PM 5/8/2018, you wrote:
Charlie thanks
This is a crew controlled feed from the battery . . .
not expected to be 'hot' on approach-to-the-rocks.
If contact with the ground is un-controlled . . .
then the whole system is likely to be hot . . .
existence of circuit protection probably has
no useful effect on the outcome.
