Zenith601-List Digest: 1 Msgs - 04/26/18
dwbbrown(at)gmail.com
PostPosted: Fri Apr 27, 2018 6:04 pm    Post subject: Zenith601-List Digest: 1 Msgs - 04/26/18 Reply with quote
Bill, My Jabiru is about 10 years old, 825 hours, with none of the problems you described
David
Sent from my iPad
[quote] On
Time: 12:17:41 PM PST US
Subject: Zenith601 Jabiru Starter Trashed
Zodiac Forum Members,
My Bosch starter on my Jabiru 3300, Zodiac 601 failed after mostly ground
runs and very little flight time.
The pinion gear moved on its shaft and began grinding away at the aluminum
housing until the bendix would no longer activate.
Obviously this condition had been occurring for some time as the steel gear
milled out two notches in the nose housing.
I need a new housing but wonder how to prevent the same defect from
occurring again. I don't see any thing that would prevent the pinion from
sliding out again.
Has anyone on the forum had experience with this?
Bill Page
Zodiac 601HDS with early Jabiru 3300
(FrontPage(at)rcn.com)
Pennsylvania
