Zenith601-List Digest: 1 Msgs - 04/24/18
dwbbrown(at)gmail.com
PostPosted: Wed Apr 25, 2018 4:39 am    Post subject: Zenith601-List Digest: 1 Msgs - 04/24/18 Reply with quote
I also use a bore scope and a close eye inspection at annual. Also I have always given a gentle up and down shake to the horizontal stabilizer as part of every preflight.
David
601XLB
On Apr 25, 2018, at 01:48, Zenith601-List Digest Server <zenith601-list(at)matronics.com> wrote:
Today's complete Zenith601-List Digest can also be found in either of the
of the Zenith601-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-04-24&Archive=Zenith601
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-04-24&Archive=Zenith601
Zenith601-List Digest Archive
Total Messages Posted Tue 04/24/18: 1
Today's Message Index:
1. 08:05 AM - Re: Zenith601-List Digest: 2 Msgs - 04/23/18 (Comcast)
________________________________ Message 1 _____________________________________
Time: 08:05:48 AM PST US
Subject: Re: Zenith601-List Digest: 2 Msgs - 04/23/18
I use a bore scope to get a good look. My brackets are painted so if a crack appears,
it should show by means of broken paint.
I do look now at every oil change.
Mine fit snug during assembly so I dont believe there is unintended stress.
I do keep my eye open for it though
- Rich
>> On Apr 24, 2018, at 1:47 AM, Zenith601-List Digest Server <zenith601-list(at)matronics.com>
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-04-23&Archive=Zenith601
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-04-23&Archive=Zenith601
> Total Messages Posted Mon 04/23/18: 2
> 1. 06:56 AM - Horizontal Stabilizer Safety Bulletin 2017 (Bobby Paulk)
> 2. 07:51 AM - Re: Horizontal Stabilizer Safety Bulletin 2017 (Paul Mulwitz)
> Time: 06:56:14 AM PST US
> From: Bobby Paulk <bobbypaulk(at)comcast.net>
> Subject: Horizontal Stabilizer Safety Bulletin 2017
> While doing my "Condition" Inspection I found out about the cracked attach brackets
> on the Zodiac. I examined all the visible ones very carefully and found no
> problems. I believe the cracking is due to very poor workmanship and using an
> over sized washer that extended into the curved radius of the bend in the metal.
> The photos on the site are a sign of very poor workmanship and not a design
> problem. My plane was built using the fast build kit and the Horizontal Stabilizer
> spar and attach fittings came assembled from the factory.
> I would like to know what most builders are doing about the 2 angles inside the
> skin. At this time I do not believe I will remove and cut the hole to examine
> them.
> Any input from builders would be appreciated.
> Thank You
> Bobby
> Zodiac 601 "B"
> Jabiru 3300 295 hrs.
> ________________________________ Message 2 _____________________________________
> Time: 07:51:32 AM PST US
> Subject: Re: Horizontal Stabilizer Safety Bulletin 2017
> From: Paul Mulwitz <psm(at)att.net>
> I'm not sure I understand the attach bracket problem. That said, I
> didn't like the way the 4 aluminum parts holding the horizontal
> stabilizer in place on my Zodiac XL were performing. The stabilizer
> could be moved easily by applying force on the end. So I changed them
> to steel. The stabilizer is firmly attached on my plane.
> We should remember there was no revision control on the Zodiac XL
> changes. It is possible that each one of the thousand copies of this
> design is different from the others.
> Paul
> Camas, WA
> CH601 XL (I installed the upgrade but didn't change the part number to
> "B". My plane was already registered when Zenith decided the upgrade
> changed the part number.)
>> attach brackets on the Zodiac. I examined all the visible ones very
>> carefully and found no problems. I believe the cracking is due to very
>> poor workmanship and using an over sized washer that extended into the
>> curved radius of the bend in the metal. The photos on the site are a
>> sign of very poor workmanship and not a design problem. My plane was
>> built using the fast build kit and the Horizontal Stabilizer spar and
>> inside the skin. At this time I do not believe I will remove and cut
>> the hole to examine them.
>> Thank You
>> Bobby
>> Zodiac 601 "B"
