Protection for Battery Master Switch wire?
PostPosted: Mon Apr 09, 2018 7:46 am    Post subject: Protection for Battery Master Switch wire? Reply with quote
At 09:30 AM 4/9/2018, you wrote:
--> AeroElectric-List message posted by: "rsmith52" <rodsmith52(at)yahoo.com>
I plan on using Figure Z12 as the architecture for wiring my Bearhawk. In the process of converting the diagram to physical location for equipment and wire runs I noticed that the only wire that doesn't seem to have any protection, or is kept very short, is the Battery Master switch wire, 22ga running from the battery contactor to the switch? I could not find a discussion of this doing a search.
There is no failure mode that puts that wire
at risk. "Pull to ground" control lines on
contactors have never benefited from protection.
