AeroElectric-List Digest: 2 Msgs - 03/29/18
websurfshop(at)gmail.com
PostPosted: Fri Mar 30, 2018 7:57 am    Post subject: AeroElectric-List Digest: 2 Msgs - 03/29/18 Reply with quote
Ok, thanks, I got out my special email decoder and deciphered the message Wink
The radio will only draw the current it needs, as long as the voltage isn't too high=2E The fuse protects=C2- the wire=2E 1A fuse would be marginal, since you can expect the radio to draw somewhere near the design output current of the supply=2ECut the wire off the adapter, connect through a 2A fuse to the a/c bus=2E Or better, just buy the proper connector and some wire, and keep the existing power supply intact=2E=81=A3Charlie=8B
On Thu, Mar 29, 2018 at 11:30 PM, AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)> wrote:
Today's complete AeroElectric-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the AeroElectric-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2018-03-29&Archive=AeroElectric
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2018-03-29&Archive=AeroElectric
                           AeroElectric-List Digest Archive
                     Total Messages Posted Thu 03/29/18: 2
Today's Message Index:
     1. 09:43 PM - Hardwire an old ICOM IC-A21 handheld radio  (David)
     2. 10:03 PM - Re: Hardwire an old ICOM IC-A21 handheld radio  (Charlie England)
________________________________  Message 1  _____________________________________
Time: 09:43:48 PM PST US
From: David <websurfshop(at)gmail.com (websurfshop(at)gmail.com)>
Subject: Hardwire an old ICOM IC-A21 handheld radio
I would like to provide power to an older ICOM A21 handheld radio in my
plane outfitted with an B&C SD-8, in the case of radio battery failure.
The radio came with a wall plug AC to DC adapter that puts out 13.5v at
1000mA.  How can I hardwire power to the radio and make sure it limits the
current so I don't smoke my radio?  Can I just cut the cord off the AC-DC
adapter and run it to a fuse block with a 1 amp fuse?
Thanks,  David
________________________________  Message 2  _____________________________________
Time: 10:03:29 PM PST US
Subject: Re: Hardwire an old ICOM IC-A21 handheld radio
From: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
=81=A3Charlie
=8B
On Mar 30, 2018, 12:48 AM, at 12:48 AM, David <websurfshop(at)gmail=2Ecom
 in my
ure=2E
=2E5v at
>1000mA=2E  How can I hardwire power to the radio and make sure it
 limits
>the
ff the
>AC-DC
>Tha
nks,  David
WIKI -
BARRY CHECK 6
PostPosted: Sun Apr 01, 2018 7:08 am    Post subject: AeroElectric-List Digest: 2 Msgs - 03/29/18 Reply with quote
Talk about needing a DECODER RING!!!
Please re-post  WITHOUT using any icons or quotes.
Barry
PS
I lost my Decoder in a jar of Ovaltine.
On Fri, Mar 30, 2018 at 11:56 AM, David <websurfshop(at)gmail.com (websurfshop(at)gmail.com)> wrote:
HTML Version:
Text Version:
Thanks,  David
=81=A3Charlie
=8B
 in my
ure=2E
=2E5v at
 limits
>the
ff the
>AC-DC
>Tha
nks,  David
WIKI -
PostPosted: Sun Apr 01, 2018 8:32 am    Post subject: AeroElectric-List Digest: 2 Msgs - 03/29/18 Reply with quote
I don't know where the extra characters came from. But I'll be happy to refrain from trying to help you in the future. Smile
Charlie
On Apr 1, 2018, at 10:12 AM, FLYaDIVE <flyadive(at)gmail.com (flyadive(at)gmail.com)> wrote:
Barry
PS
The radio will only draw the current it needs, as long as the voltage isn't too high=2E The fuse protects=C2- the wire=2E 1A fuse would be marginal, since you can expect the radio to draw somewhere near the design output current of the supply=2ECut the wire off the adapter, connect through a 2Afuse to the a/c bus=2E Or better, just buy the proper connector and some wire, and keep the existing power supply intact=2E=81=A3Charlie=8B
HTML Version:
Text Version:
Thanks, David
=81=A3Charlie
=8B
in my
ure=2E
=2E5v at
limits
>the
ff the
>AC-DC
>Tha
nks, David
WIKI -
