Posted: Fri Mar 23, 2018 2:48 am Post subject: Fwd: Re: Cowl heat protection |
Not surprised. I used visible heat damage (from structural composite damage to singed paint) to guide my coverage. There may be more going on than simply proximity of exhaust system parts to cowling.
I guess the 'safer' but slightly heavier approach would be to cover it all as Tim suggested.
On 3/20/2018 9:49 PM, Don McDonald wrote:
| Quote: | I took a pencil and marked the areas that were fairly close to any exhaust pipe (with the bottom cowl on). It looks like your area covered is smaller than mine.... just sayin'.
On Tuesday, March 20, 2018, 5:52:10 PM CDT, Bill Watson <Mauledriver(at)nc.rr.com> (Mauledriver(at)nc.rr.com) wrote:
Here's what I did after allowing heat to damage my cowling. The bad
news is that I had to repair the cowling's inside surface and structure
(scarfing, cloth, honeycomb). The good news is that I had a real good
indication of where the heat problem was. I have flown 2 years since
then with no additional damage or concern. I used red RTV to adhere
the pieces of foil faced insulation - probably the same stuff Tim used
but not sure.
www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
