ptag.dev(at)talktalk.net Guest
Posted: Sat Mar 17, 2018 12:43 pm Post subject: Black Brake Pipe........ |
Thanks for your trouble Alan , as a result of Karen not grasping the difference I have 5 meters of the same you have, which for my purpose is not required! I only require the 0.248 inches. Diameter.
Bob Harrison G-PTAG Kit337
kingsnjan(at)westnet.com. Guest
Posted: Sat Mar 17, 2018 1:23 pm Post subject: Black Brake Pipe........ |
Hello Bob,
I'm sure I still have the pipe supplied with my kit.
If you can't procure any locally, let me know and I'll send it over. That's if you wouldn't rather pop over to collect it!
Cheers
Kingsley
Posted: Sat Mar 17, 2018 4:35 pm Post subject: Black Brake Pipe........ |
Bob,
In case you wonder why I said "I think!" I have some pipe, the reason is that I am presently 1500 km from home and won't be home till late in the week.
Having said that, I didn't use mine so feel confident I will be able to fill your order!
Best
Kingsley
budyerly(at)msn.com Guest
Posted: Sun Mar 18, 2018 8:02 am Post subject: Black Brake Pipe........ |
Bob,
I see this all the time in the US. Getting the black pipe is not easy as it is UK type pipe fittings are non aviation.
The 6mm tubing used is for Kart operations in the UK as are the fittings. If Karen can’t supply try cometkartsales.com for this specific tubing and fittings may help.
Note For North American Customers: In my shop I convert the brake lines to all Matco for my clients when I can. Lines and fittings all match all the time. For those of you in the UK, I know the approval of same or better using an aircraft brake manufacturer is quick and easy. I also note that, on a re-plumb of a trigear, will use the 1/16 inch Matco lines and fittings. Very good stuff and from a consistent manufacturer. Just slip the smaller line into the old tubing for a quick, permanent and properly operating repair. Some notes are in the .pdf attached.
Bud Yerly
Sent from Mail for Windows 10
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Bob Harrison <ptag.dev(at)talktalk.net>
Sent: Saturday, March 17, 2018 4:42:35 PM
Subject: Black Brake Pipe........
Brake_installations_to_consider_on_a_Trigear_Conversion.pdf |
1.07 MB |
435 Time(s) |
