iLevil & Replacement Fuel Feed
willydewey
PostPosted: Thu Mar 15, 2018 7:24 am    Post subject: iLevil & Replacement Fuel Feed Reply with quote
Hi Guys
I have bought an iLevil 3SW and would appreciate advice where to fit it avoiding or minimising magnetic effects.. It could go on or under the parcel shelf on my 914 trigear or in the roofspace between the doors, I am just not sure hence the plea for advice.
We have just completed the LAA mod for the replacement rubber at the lower end of the polypropylene filler using the specified bent aluminium tube and the fluorsilicate connecting pieces It was a simple process, however the original rubber elbow was found to be in perfect condition with no signs of deterioration whatsover. Another £85 wasted but well worth the inspection.
Give a wise man knowledge and he will be yet wiser
clivesutton
PostPosted: Thu Mar 15, 2018 8:12 am    Post subject: Re: iLevil & Replacement Fuel Feed Reply with quote
Hi Bill,
I've put mine behind the RH panel on top of the tunnel and on top of a foam/GF fabricated 'wedge' to bring it level in flight. Actually there is an article in with Tony Wickens that i expect will be published in the EF. Despite 'seeing' the UC frame, it seems to work fine so far. I've tried to attach a pic to this message that illustrates . . .
Clive
 Filesize:  2.72 MB
 Viewed:  3842 Time(s)
