Average Fuel Burn
lsvance54
PostPosted: Tue Mar 06, 2018 1:24 pm    Post subject: Average Fuel Burn Reply with quote
I have an Allegro 2000 with a 912UL 80 HP engine.
The operator’s manual suggests premium auto gas, which is what I have used almost exclusively. Prior to my recent annual inspection I was burning on average two gallons of fuel per hour. During the annual I had the carbs rebuilt and did the ROTAX 5 year rubber replacement. Now I am averaging 1.775 gallons of fuel per hour.
Am I extremely fortunate or is this normal for the little bird?
SN: 06-230
TT: 542 hours A&E
N25017[/list]
Scott
N25017
hgmckay
PostPosted: Tue Mar 06, 2018 2:25 pm    Post subject: Average Fuel Burn Reply with quote
Scott,
If your numbers are correct you are indeed fortunate. I am in North Carolina
and have an Allegro 2000 ELS (N661WW) with almost 800 hours on my Rotax 912
UL 80 HP engine. I built the airplane from the Kit ten years ago. I have
been the sole owner and I keep my carbs pneumatically balanced. The best
average fuel consumption I have ever gotten was 3.0 gph. At the present my
fuel consumption is averaging 3.6 gph. I burn exclusively ethanol free auto
fuel (MOGAS) either 90 octane or 87 octane. Where are you located Scott?
Hugh G. McKay III, P.E. Fellow, L.M. ASCE
Senior Consultant
Worldwide Engineering Inc.
4090 North NC Hwy. 16
Denver, NC 28037
Ph. 704-661-8271
Fax 704-483-5466
email hgmckay(at)bellsouth.net
http://www.wwegeo.com
N456TS
PostPosted: Thu Mar 08, 2018 9:33 am    Post subject: Re: Average Fuel Burn Reply with quote
Wow!
That's a good fuel burn rate. What's your typical cruise speed at that GPH?
N456TS
lsvance54
PostPosted: Thu Mar 08, 2018 12:31 pm    Post subject: Re: Average Fuel Burn Reply with quote
I typically cruise between 98 - 105 MPH.
Since getting out of annual, I have only been able to fly about five hours.
As I fly more I will be sure to monitor very closely. Not unhappy with being able to fly for less than six bucks an hour!
I am based out of KCJR, Culpeper, VA.
Scott
N25017
Scott
N25017
N456TS
PostPosted: Sun Mar 11, 2018 3:57 pm    Post subject: Re: Average Fuel Burn Reply with quote
GPH (and Dynon Skyview) is why I have an LSA. 100 Knots-115 MPH (at) 3.5-4 GPH. The economics can't be beat.
N456TS
