Flight Control for the Mono.
ward.t(at)xtra.co.nz
PostPosted: Thu Mar 01, 2018 11:54 pm    Post subject: Flight Control for the Mono. Reply with quote
Hi All,
Just designed a Flight Control Locking device after spying a similar cunning device in a Mono which Peter Jeffers and John Baranski showed me. Built for a Mono as it does not lock the rudders, however hopefully the grounded tail wheel will take care of that.
See photo attachments and if any builder/owner requires the profile template for the aluminium plate, I am happy to send it to them.
Hope you are keeping warm over in the UK. “The beast from the East”they are reporting!
Antipodes Rep
Hope the phots come through.
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
 Filesize:  25.94 KB
 Viewed:  3564 Time(s)
 Filesize:  24.01 KB
 Filesize:  27.17 KB
 Filesize:  29.95 KB
pjeffers(at)talktalk.net
PostPosted: Fri Mar 02, 2018 1:52 am    Post subject: Flight Control for the Mono. Reply with quote
Well copied Tim,
I would not have recognised that it was a different aircraft.
Pete
PS are you still intending to come home in time for the Skype meeting this snowy am here in the UK?
PostPosted: Fri Mar 02, 2018 2:14 am    Post subject: Flight Control for the Mono. Reply with quote
Hi Pete,
I should be on Skype tonight.
Tim Ward,
12 Waiwetu Street,
Fendalton,
Christchurch 8052
New Zealand
Ph; 03 3515166
Mob; 0210640221
email; ward.t(at)xtra.co.nz
