		AlaskaChang801
				 Posted: Tue Feb 20, 2018 9:41 am    Post subject: Canopy latch modification. |
				Anyone have a picture of a canopy latch mod where they added to the push button to make opening the canopy from the outside.
 Thanks.
				 Posted: Tue Feb 20, 2018 10:37 am    Post subject: Canopy latch modification. |
				Try this.
 Drill and tap the center of the push button for a 10-32 thread.  Using an AN3-10 bolt (or close to it), thread the bolt into the drilled and tapped 10-32 hole in the button.  Next, cut off the head of the bolt and finish off the end of the bolt with a file.  The length of bolt after it is cut of should be about 1/2" to 5/8".   To open, simply push down on the end of the bolt rather than trying to push in on the button.
 If you want long term security for the bolt, put a small amount of JB Weld epoxy on the bolt threads before you thread the bolt into the hole.
 Dennis
  To: yak-list(at)matronics.com
  Sent: Tuesday, February 20, 2018 12:44 PM
  Subject: Canopy latch modification.
 --> Yak-List message posted by: "AlaskaChang801" <themilnes95(at)gmail.com (themilnes95(at)gmail.com)>
 Thanks.
 http://forums.matronics.com/viewtopic.php?p=478138#478138
        - The Yak-List Email Forum -
 _=====================
 http://wiki.matro========================
		AlaskaChang801
				 Posted: Tue Feb 20, 2018 11:43 am    Post subject: Re: Canopy latch modification. |
				Thanks for the reply and it’s exactly how Doug Sapp explained someone had done it, so I appreciate you elaborating on the mod.
 I’ll give it a try.
		Clouddog
				 Posted: Sat Feb 24, 2018 4:47 am    Post subject: Canopy latch modification. |
				I'll get a picture to you when I get home next week. Basically I drilled a 3/16" hole, tapped it, found a stainless bolt with a round hex key round head, slid a plastic sleeve over the threads and that's it. Make sure you will into the push button in a location to get s good depth for the bolt to screw into.
 I'm out if town but will try and get a picture when I return.
 On Feb 20, 2018 12:46 PM, "AlaskaChang801" <themilnes95(at)gmail.com (themilnes95(at)gmail.com)> wrote: 	  | Quote: | 	 		  --> Yak-List message posted by: "AlaskaChang801" <themilnes95(at)gmail.com (themilnes95(at)gmail.com)>
  Thanks.
  List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
   FORUMS -
  WIKI -
  b Site -
            -Matt Dralle, List Admin.
		AlaskaChang801
				 Posted: Sun Feb 25, 2018 6:16 pm    Post subject: Re: Canopy latch modification. |
				CloudDog. I’d really appreciate the picture. Thanks.
		stephen.hayne
  Joined: 01 Nov 2013 Posts: 59 Location: United States
				 Posted: Wed Feb 28, 2018 9:21 am    Post subject: Re: Canopy latch modification. |
				I did this, but instead of a bolt, used a "single-wing" bolt from ACE - can't find a pic at this time, but the bolt looked a bit like this, but without the hole... much easier to press on.
 https://www.e-rigging.com/assets/images/p/1244/five-sixteenths-inch-x-three-eighths-inch-stainless-eye-tab-bolt.jpg
 Only downside is that the steel seems a bit soft and it has "bent" just a little in use.  With the tab, though, it is easy to take out and replace...
  _________________ -
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
 http://selfsynchronize.com/hayne/plane/cj6.asp |
		AlaskaChang801
				 Posted: Wed Feb 28, 2018 2:31 pm    Post subject: Re: Canopy latch modification. |
 Thanks for the input and will look into it. I have a couple AN bolts coming tomorrow and will go from there.
