D-sub connection ground wires connection
maxb
PostPosted: Thu Feb 15, 2018 11:35 pm    Post subject: D-sub connection ground wires connection Reply with quote
Often in a D-Sub connector there are multiple ground connection. When joining the various ground (wire or shielded wire braid) do you join them together with ring terminal connectors, or solder them together on some kind of plate?
Screwed terminal are exposed to the possibility of become loose, soldered are less practical to maintain (even if this necessity is remote)
(the question is: is it better to sold them or join with some kind of detachable terminal?)
Thanks to the community!
maxb
