Uavionix echoUAT+SkyFYX
ChasB(at)satx.rr.com
PostPosted: Wed Feb 07, 2018 8:04 am    Post subject: Uavionix echoUAT+SkyFYX Reply with quote
Van, et. al.,
I have installed and certified the echoUAT+SkyFYX in my RV-6A. Installation was easy other than having to get under the instrument panel. I installed the external echoUAT transponder antenna at the firewall and on the opposite side of the fuselage from my existing transponder antenna. Doesn’t quite meet the 36 inch separation requirement, but seems to work okay. My existing GPS antenna is mounted on a firewall bracket under the cowl and there was room to put the SkyFYX antenna on the bracket. Punched a hole in the firewall to run RG-400 cable. B&C connectors come with the assembly. Mounting the echoUAT was a bit problematic until I found a location for it, but installation was a snap. echoUAT box is smaller than a pack of cigarettes. Power and ground wires are easy. Mating with the existing transponder was easy and instructions are included for several brands of acceptable transponders. Mine was an SL-70. I ordered the system from the factory rep who was a great support help in programming the echoUAT. You use an IPad, iPhone or other tablets/phones to program the system. The uAvionix rep was Shane Woodson at (214) 909-1515.
I’ll be glad to answer any other questions you can come up with.
Charlie Brame
RV-6A N11CB
San Antonio
