Antenna cable?
n233ee(at)gmail.com
PostPosted: Fri Feb 02, 2018 8:48 am    Post subject: Antenna cable? Reply with quote
The recent discussions about shielded cable brought to mind a question.
I am in the process of installing a Garmin GDL-82 in an experimental aircraft. The GDL-82 was purchased from Pacific coast aviation and arrived without any antenna cable since the installed length was unknown.
The online instructions warned of a possible signal loss if ‘standard’ RG 58 coax was retained from the transponder output to the antenna suggesting changing to RG 400 or equivalent. I am under the gun to get the installation completed so a trip to the local Hutch & Son was an attempt to eliminate the shipping wait but they did not stock any 400 and did not have an equivalent. They also thought the ‘400’ was an indication of the outside diameter as well as a lower signal loss.
I have found some RG-400 cable on both eBay and Amazon but their diameters are close to the RG 58.
Now the question is how do I determine the true RG 400 and what to use to limit the signal loss is a cable run of six feet from the transponder to the antenna. The GDL-82 is four feet from the transponder and two feet from the antenna. (The GDL-82 is spliced into the transponder output cable on the way to the antenna to pickup the code, standby, and altitude etc.)
I am inviting comments, suggestions and/or advice. Thanks, Earl
gilles.thesee(at)free.fr
PostPosted: Fri Feb 02, 2018 9:07 am    Post subject: Antenna cable? Reply with quote
Hello Earl
Some info on the RG 400 coaxial
http://www.awcwire.com/productspec.aspx?id=rg400-coaxial-cable
Double braided shield, PTFE dielectric, etc.
And yes the diameter is close to that of the old RG 58.
B&C, Aircraft Spruce or any aviation supplier carry them.
FWIW,
Best regards,
Gilles
http://contrails.free.fr
stein(at)steinair.com
PostPosted: Fri Feb 02, 2018 9:22 am    Post subject: Antenna cable? Reply with quote
The 400 does not refer to the diameter (it's nearly identical to the 5Cool...and beware of some of the Ebay stuff. There is much out there from recent hurricane sales that has been under water and can be corroded. Not all of it of course, but SOME. Anyway, to be sure if it's correct, just buy it from an aviation/avionics shop and you'll be guaranteed it's good stuff that isn't old surplus or something.
Now, as an aside - depending on the transponder you have (and how it's performing before the upgrade/addition of the 82), the 58 you currently have might work just fine, at least temporarily....
Stein
PostPosted: Fri Feb 02, 2018 10:44 am    Post subject: Antenna cable? Reply with quote
It's difficult to 'fake' RG-400 . . . any of
these offerings of cable and connectors will
be suited to your task.
https://goo.gl/jg2ocw
Kellym
PostPosted: Fri Feb 02, 2018 12:18 pm    Post subject: Antenna cable? Reply with quote
I agree with Stein....for your cable lengths, RG58 will do just fine for
the short run. Yes, the RG400 is better, especially for the long term,
but whether the difference can be detected by a ramp test set or not...I
doubt it. The RG 400 has clear insulation over bronze/gold looking
interior and generally costs $3 and up per foot.
Kelly McMullen
KCHD
