Fuel Totalizer Circuit
sturs
PostPosted: Mon Jan 22, 2018 2:12 am    Post subject: Fuel Totalizer Circuit Reply with quote
A friend of mine is having an issue with the fuel totalizer on his aircraft. Basically it doesn't work (is dead) and seems that it may have suffered from a voltage spike whilst starting the a/c from a boost starter.
Fault finding would be much easier if anyone has access to a circuit diagram of the device. Does anyone on here know where to find one? We have the user manual - but that only shows the external wiring to the power and transducer. It's a Hoskins Model FT101A.
Any help would be very much appreciated. Thanks for reading this.
Stuart
PostPosted: Mon Jan 22, 2018 4:52 am    Post subject: Re: Fuel Totalizer Circuit Reply with quote
Download this pdf:
https://img1.wsimg.com/blobby/go/5fd0aa27-961d-44f2-853d-76b9736fb4af/downloads/1bono4lcn_734052.pdf
Edit: Never mind. This pdf is probably what you already have, showing external wiring only.
Joe Gores
sturs
PostPosted: Mon Jan 22, 2018 9:17 am    Post subject: Re: Fuel Totalizer Circuit Reply with quote
Hi Joe,
Yes, that's the one we've already got - but thanks anyway. The problem is there's clearly a fault on the circuit board somewhere - and I don't think I can find it without a circuit diagram.
Cheers, Stu
millner(at)me.com
PostPosted: Mon Jan 22, 2018 6:12 pm    Post subject: Fuel Totalizer Circuit Reply with quote
Don't have the diagram, but I think I have a removed-good unit in my
hangar...
Paul
Stuart
http://forums.matronics.com/viewtopic.php?p=477495#477495
sturs
PostPosted: Tue Jan 23, 2018 12:49 am    Post subject: Re: Fuel Totalizer Circuit Reply with quote
Thanks Paul. My friend already has a replacement - which took him a long time to find. Mind you he’s rather unwilling to take the ‘new’ one apart and use that as an example to check against the other!
Thanks for the offer, though. Much appreciated.
Cheers, Stu
