Need a device to send 12volts when all 3 green lights ar
jskiba(at)icosa.net
PostPosted: Thu Jan 11, 2018 3:03 pm    Post subject: Need a device to send 12volts when all 3 green lights ar Reply with quote
Then I would lose each gear indication. This is for an audio alert device input if the gear is not down and locked (all 3)
Sent: Thursday, January 11, 2018 3:04 PM
Subject: Re: Need a device to send 12volts when all 3 green lights are light
At 02:01 PM 1/11/2018, you wrote:
On 1/11/2018 1:37 PM, Jeffrey W. Skiba wrote:
Below is the landing gear circuit, I need a device or build one that can use the 12volts coming from the gear down and locked switches and only send 12 volts to another device[for testing a led] IF ALL 3 lights (gear down and locked)
Can you just hook all the down-lock switches in series?
