Need GNS 480 and Navworx help
Mauledriver(at)nc.rr.com
PostPosted: Fri Jan 05, 2018 9:48 am    Post subject: Need GNS 480 and Navworx help Reply with quote
I haven't been following the 480 AMOC for position source discussion.  I have successfully connected up my G430 to NAVWORX per the AMOC.  To do so I had to 1) have the right version of the Navworx SW as Rene stated and 2) wire it up according to the latest Navworx manual.  There seem to be at least 2 wires for all the Garmin connections and possibly 4 for the 480 (GPS data and Time Mark).
Try this link for the manual I used - see page 74.  Navworx Installation Manual
Good luck.
On 1/5/2018 10:58 AM, Sheldon Olesen wrote:
--> AeroElectric-List message posted by: Sheldon Olesen <saolesen(at)sirentel.net> (saolesen(at)sirentel.net)
While doing my annual, I took time to run a wire from my 480 to the Navworx box. I fiddled with the 480 software to set it to the ADS-B out setting and did the same with Navworx to accept the 480 input. I rolled the plane out in to the subzero WI weather to view the GPS satellites and got nothing. The 480 wasn’t talking to the 600B.
I used: P1-6 for serial 3 out at 9600 from the 480
Pin 34 on the 600B
UAT software 4.1
The 480 has the ADS-B out software installed
In the 480 Ground Service Mode, there was no activity showing on Serial 3 in the monitor mode.
Where am I going wrong?
Sheldon Olesen
RV-10 N475PV 791 hrs
Sent from my iPad
Kellym
PostPosted: Sat Jan 06, 2018 3:21 pm    Post subject: Need GNS 480 and Navworx help Reply with quote
Garmin's software that output ADS-B did not fully meet the final rule,
so they had to revise it and give it the name ADSB+. Your transponder
has to have software that accepts ADS-B+, and your GPS has to have
software to output ADS-B+. Without the plus it is not legal. So you have
to determine which software version added that protocol for both the GPS
and for the transponder.
On 1/6/2018 10:46 AM, Airdog77 wrote:
Sheldon,
Just to confirm, when you say that your
does that mean you have the latest 2.4 software version on your unit?
I ask because I've seen discussions on ADS-B vs ADS-B+ out there, and there seems to be confusion between the two. Version 2.3 will give you ADS-B, but to drive an S-mode transponder for ADS-B you need 2.4.
Again, just double-checking.
Cheers,
Wade
Airdog
Wade Parton
Building Long-EZ N916WP
www.longezpush.com
http://forums.matronics.com/viewtopic.php?p=477121#477121
Kelly McMullen
KCHD
