Flibob
Posted: Thu Dec 14, 2017 8:39 am Post subject: CJ engine sling |
I am getting ready to install a new (zero time Chinese) engine. What are people using for engine slings. And any words of wisdom on install and run
in.
Thanks Bob
47.93 KB |
5235 Time(s) |
woodja51
Joined: 13 May 2015 Posts: 40 Location: MELBOURNE AUSTRALIA
Posted: Fri Dec 15, 2017 12:00 am Post subject: Re: CJ engine sling |
Wow ... you are lucky to have a zero timed engine ... I would suggest you fully
Depreserve it while its sitting there - oil in Carb , check magnetos clear and correctly put together internally / cigar etc ( take caps off) hot oil into front and rear crankcases , cylinders etc ..check all the screens , check the timing order is 135792468 - the Chinese diagram is slightly wrong and often misrouted no 7 airline .. dress as much as you can before installation as it’s easier than working around mounting frames etc .check the lower intake has the flattened section - or throttle won’t work, check baffles have holes in correct spot for controls blast tubes etc ... much easier to do on stand than airframe .. a bunch of other things might crop up but looks great !
Lancer
Joined: 21 Apr 2016 Posts: 30 Location: Cairns, Australia
Posted: Fri Dec 29, 2017 3:45 am Post subject: Re: CJ engine sling |
Where did you pick up this little gem??
_________________ You can run but you can't hide |
