Europa-List Digest: 4 Msgs - 12/19/17
roger47grainger(at)gmail.
PostPosted: Wed Dec 20, 2017 11:46 am    Post subject: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
Hi Tim Ward,
I am very interested in one of your aluminium Europa fuel filler pipes, I recently had to cut mine off to remove it only to find it was actually ok and now require a replacement.
Can you please let me know availability and how best to proceed with ordering.
Many Thanks,
Roger Grainger
G-CICA
On 20 Dec 2017, at 07:49, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-12-19&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-12-19&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Tue 12/19/17: 4
Today's Message Index:
1. 01:15 AM - Re: Re: Aluminium Elbow (GTH)
2. 03:09 AM - Re: LAA Airworthiness Alert. AIL December 2017 All Europas (clivesutton)
3. 06:15 AM - LAA Standard Mod for 13070 (replacement of classic fuel hose with aluminium) is now approved (Pete Lawless)
4. 06:35 AM - Re: Re: LAA Airworthiness Alert. AIL December 2017 All Europas (Pete Lawless)
________________________________ Message 1 _____________________________________
Time: 01:15:17 AM PST US
Subject: Re: Re: Aluminium Elbow
Le 18/12/2017 23:45, Kelvin Weston a crit :
> No, it's not peel ply. I think it is a tracer thread woven into the glass fabric
to ensure the glass is laid up in the correct orientation during the moulding
lay-up.
Kevin,
Thank you for your answer. I must confess I have experience only with
carbon fiber so no lines in the layup.
All the best with your project.
Best regards,
Gilles
http://contrails.free.fr
________________________________ Message 2 _____________________________________
Time: 03:09:33 AM PST US
Subject: Re: LAA Airworthiness Alert. AIL December 2017 All Europas
As you say Bob, lots of activity behind the scenes.
MOD79 may also bring something to the party for some Europa-owners (LAA aware).
The black silicone hoses in that MOD kit have a green fluoro fuel-resistant
lining.
http://www.europa-aircraft.com/upload/Modification%20Bulletin%20No%2079%20(Issue%2003).pdf
Liking the new look/feel and regular updates of the website btw . . .
http://forums.matronics.com/viewtopic.php?p=476599#476599
________________________________ Message 3 _____________________________________
Time: 06:15:50 AM PST US
Subject: LAA Standard Mod for 13070 (replacement of classic fuel hose
Hi All
I have just received this from Andy Draper.
"The SM has now been signed off by Francis and its now in the system to
be posted on the LAA web site."
Anyone with a Classic filler hose who wants to replace it with aluminium
can do so using this mod. John Archer <77alembert(at)gmail.com> is
collecting names of those wanting a replacement pipe.
Pete
G-RMAC Classic #109
________________________________ Message 4 _____________________________________
Time: 06:35:00 AM PST US
Subject: Re: Re: LAA Airworthiness Alert. AIL December 2017 All Europas
Can't seem to find this mod listed in the LAA list of Europa standard mods.
Pete
lining.
ward.t(at)xtra.co.nz
PostPosted: Wed Dec 20, 2017 8:04 pm    Post subject: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
Hi Roger,
The manufacturer is going to do another run after Christmas once we have sufficient numbers and the Mod from LAA is approved.
Will put your name on the list.
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 21/12/2017, at 8:45 AM, Roger Grainger <roger47grainger(at)gmail.com> wrote:
Hi Tim Ward,
Many Thanks,
Roger Grainger
G-CICA
> HTML Version:
> Text Version:
> From: GTH <gilles.thesee(at)free.fr>
> lay-up.
> Kevin,
> Best regards,
> Gilles
> From: "clivesutton" <clive.maf(at)googlemail.com>
> lining.
> From: Pete Lawless <pete(at)lawless.info>
> Hi All
> Regards
> Pete
> G-RMAC Classic #109
> Pete
> lining.
Roland
PostPosted: Wed Dec 20, 2017 10:58 pm    Post subject: Re: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
Hi Tim,
please put me on the list as well.
Can you please also tell me, what outside diameter the aluminum pipe has, so that I can order the correct silicone hose to fit the ends to the filler and fuel tank? Is it also 51 mm?
Thanks!
Roland Schmidt
PH-ZTI
XS TG 914
Maikammer 9
42489 Wülfrath
Germany
PostPosted: Thu Dec 21, 2017 12:12 am    Post subject: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
Hi Roland,
Aluminium Pipe is 50.8mm Outer Diameter , wall 1.6 49.2mm Inner Diameter.
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 21/12/2017, at 7:58 PM, Roland <schmidtroland(at)web.de> wrote:
Hi Tim,
Can you please also tell me, what outside diameter the aluminum pipe has, so that I can order the correct silicone hose to fit the Ends to the filler and fuel tank? Is it also 51 mm?
Thanks!
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=476652#476652
IanCook_1(at)hotmail.com
PostPosted: Sat Dec 30, 2017 7:55 am    Post subject: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
Tim,
On inspecting the XS refuelling fuel pipe on G-CBHI today it was found US. Therefore, please add me to the list if it is suitable for the XS? Clearly the XS is a much shorter pipe than that required for the Classic. The current LAA Standard Mod does not cover the XS aircraft but Brian has indicated your pipe will suitable for both and will be the basis of the new XS LAA Standard Mod. From your previous work on this mod do you know if the same specification of pipe has been used anywhere else on the Europa? Did you find any positive way of flushing out any debris from the tank? I have not tried yet.
Ian Cook
Mail for Windows 10
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Tim Ward <ward.t(at)xtra.co.nz>
Sent: Thursday, December 21, 2017 8:12:03 AM
Subject: Re: Re: Europa-List Digest: 4 Msgs - 12/19/17
--> Europa-List message posted by: Tim Ward <ward.t(at)xtra.co.nz>
Hi Roland,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
> --> Europa-List message posted by: "Roland" <schmidtroland(at)web.de>
> Hi Tim,
> Thanks!
> Roland
> PH-ZTI
> XS TG 914
> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D476652%23476652&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=Zg6PYUhdQeDzqEYoL6FAdiTuezhNjBaingb1s3ro85c%3D&reserved=0
st Email Forum -
ook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=2znjopDjjSOxnQlSkwYbDp6WZlffY3jTSTi6kJzzG4c%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2FNavigator%3FEuropa-List&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=2znjopDjjSOxnQlSkwYbDp6WZlffY3jTSTi6kJzzG4c%3D&reserved=0
p; - MATRONICS WEB FORUMS -
ook.com/?url=http%3A%2F%2Fforums.matronics.com&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=ugH1k%2FAc4nWj2PpeX67ZMGFS4qVGRmSTkHdcOxf4qAg%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=ugH1k%2FAc4nWj2PpeX67ZMGFS4qVGRmSTkHdcOxf4qAg%3D&reserved=0
ook.com/?url=http%3A%2F%2Fwiki.matronics.com&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=vitH81w938t2MmRKBFGSiRSAWomJZdMYnXWmd7BCgSE%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwiki.matronics.com&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=vitH81w938t2MmRKBFGSiRSAWomJZdMYnXWmd7BCgSE%3D&reserved=0
p;   -Matt Dralle, List Admin.
ook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fcontribution&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=GpfR3d9pxAZ405CqAVgl6X7lMmjr%2FedJnmgD9MrxQqE%3D&reserved=0"> https://nam04.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.matronics.com%2Fcontribution&data=02%7C01%7C%7C1fdb871e077f40010dab08d5484aeb05%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636494408958548047&sdata=GpfR3d9pxAZ405CqAVgl6X7lMmjr%2FedJnmgD9MrxQqE%3D&reserved=0
 Filesize:  719.32 KB
 Viewed:  10837 Time(s)
Roland
PostPosted: Sat Dec 30, 2017 12:33 pm    Post subject: Re: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
I thought we were talking about XS all the time? I hope so, since I also have an XS.
Roland
PH-ZTI
XS TG 914
ptag.dev(at)talktalk.net
PostPosted: Mon Jan 01, 2018 6:06 am    Post subject: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
Hi! Roland,
Happy New Year .
No the main concern has been about Classic fillers located in the top of the
roof (long pipe) down to the tank. Although the failure Shown was between
the Cobra filling moulding and the tank.
Tim Wards Bent metal pipe is for between the Cobra and the tank.
The purpose of the metal piece was to reduce the smell of fuel ( obviously
in those days from absorbent rubber, especially being such a long pipe.
Bob Harrison. G-PTAG Classic Wings XS Cockpit Moulding .
Roland
PostPosted: Mon Jan 01, 2018 2:12 pm    Post subject: Re: Europa-List Digest: 4 Msgs - 12/19/17 Reply with quote
Hello Bob,
a happy new year for you, too!
As you know, I have a XS and so it was important, that Tim's aluminium pipe fits for my Europa as well, which it does apperently. I also know of at least two other XS Europas, which installed Tim's pipes more than ten years ago.
A reduction of the fuel smell in my cockpit would also be highly appreciated.
Roland
PH-ZTI
XS TG 914
