kearney
Posted: Sun Dec 10, 2017 2:36 pm Post subject: Rear floor pans |
Hi
I insulated under my front floor pans using fire break foam. I am considering doing the same think under the rear floor pans for insulation / sound proofing purposes.
I am wondering what others have done in this spot. Is there any real benefit to insulating / soundproofing here?
Inquiring minds need to know.
Les
Kelly McMullen
Posted: Sun Dec 10, 2017 5:48 pm Post subject: Rear floor pans |
No measured benefit, but I did it because I had the foam.
-sent from the I-droid implanted in my forearm
On Sun, Dec 10, 2017 at 3:36 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
| Quote: | --> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Les
http://forums.matronics.com/viewtopic.php?p=476321#476321
A&P/IA, EAA Tech Counselor
KCHD |
Gordon Anderson
Kelly McMullen
Posted: Mon Dec 11, 2017 1:19 pm Post subject: Rear floor pans |
I don't believe there is such a thing as fireproof foam. All the test results I have seen of material designed for the firewall have failed the official FAA test, 2000 degrees for a time I don't remember. Either smoke, fall apart or transfer too much heat.I don't think you need any better than what is needed for interior not against the firewall. Aircraft Spruce sells such a foam, although it doesn't pass with adhesive backing, you can get it without the adhesive, which isn't needed for the floor. The exhaust pipes are angled down and most of the exhaust stays off the bottom of fuselage.
On Mon, Dec 11, 2017 at 12:55 PM, Gordon Anderson <mregoan(at)hispeed.ch (mregoan(at)hispeed.ch)> wrote:
| Quote: | --> RV10-List message posted by: "Gordon Anderson" <mregoan(at)hispeed.ch (mregoan(at)hispeed.ch)>
Hi Les, Kelly, it has been suggested that using foam under the front floor pans can help reduce external noise caused by exhaust resonating on the underside of the fuselage. I bet no-one has done a before/after test to prove it though
Good choice to use fireproof foam - do you have specifics?
Gordon
41015 Switzerland
http://forums.matronics.com/viewtopic.php?p=476344#476344
KCHD |
kearney
Posted: Mon Dec 11, 2017 8:51 pm Post subject: Re: Rear floor pans |
Hi Gordon
I used Abesco FP200 fire rated foam.
Cheers
Les
johngoodman
Posted: Tue Dec 12, 2017 5:11 am Post subject: Re: Rear floor pans |
| kearney wrote: | Hi Gordon
Cheers
Les |
So did I....
Albert Gardner
Posted: Tue Dec 12, 2017 8:04 am Post subject: Rear floor pans |
I wish the oil would also!
Albert Gardner
N991RV
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Kelly McMullen
Posted: Tue Dec 12, 2017 5:56 pm Post subject: Rear floor pans |
It will if you keep it on the inside of the engine. 8^)Do Not Archive
On Tue, Dec 12, 2017 at 9:04 AM, Albert <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote:
Albert Gardner
N991RV
Yuma, AZ
KCHD |
