Clever Wiring for Lamp Dimmer
art(at)zemon.name
PostPosted: Thu Dec 07, 2017 5:06 pm    Post subject: Clever Wiring for Lamp Dimmer Reply with quote
Folks,
I have ten backlit switches in the panel of my plane. I need to wire all of them to the same dimmer, see the diagram on page 4 of the attached AeroRockers Circuit Diagrams, specifically the red line to the PULSE-WIDTH DIMMER box. The switches have Faston tabs. Is there some clever way to wire this? Do I just build something with a Faston terminal at one end for the dimmer and then 10 wires coming out of it, all tied up into a bundle, each with another Faston terminal?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
AeroRocker_Circuit_Diagrams.pdf
 Filename:  AeroRocker_Circuit_Diagrams.pdf
 Filesize:  567.84 KB
 Downloaded:  1464 Time(s)
enginerdy(at)gmail.com
PostPosted: Thu Dec 07, 2017 5:25 pm    Post subject: Clever Wiring for Lamp Dimmer Reply with quote
Maybe you can wire a running string of fast-ons with two wires coming out of each fast-on? It reduces reliability to wire in series like that, but switch illumination is relatively(?) non-critical..
Daniel
On Dec 7, 2017, at 7:06 PM, Art Zemon <art(at)zemon.name (art(at)zemon.name)> wrote:
Folks,
  -- Art Z.
<AeroRocker Circuit Diagrams.pdf>
Eric Page
PostPosted: Thu Dec 07, 2017 7:07 pm    Post subject: Re: Clever Wiring for Lamp Dimmer Reply with quote
How about using Bob's concept for power and ground buses based on a D-Sub connector, but use it to tie your switch illumination lines together? His example uses a DB-25 connector, but you could substitute a DB-15 since you need fewer pins.
http://aeroelectric.com/Pictures/Grounding/Minibus1.jpg
Get both male and female connectors. Bridge all of the pins together on one of them, then solder your wires to the solder cups on the other one. Mate the connectors and you've got a switch illumination bus.
Male: https://www.digikey.com/short/qqq39z
Female: https://www.digikey.com/short/qqq39m
ceengland7(at)gmail.com
PostPosted: Thu Dec 07, 2017 9:02 pm    Post subject: Clever Wiring for Lamp Dimmer Reply with quote
On 12/7/2017 7:06 PM, Art Zemon wrote:
Folks,
    -- Art Z.
https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
That would work fine, or for wiring convenience, you could do multiple joints using the same technique. Say, 3 in the 1st faston, and 3 or 4 into a butt splice on the end of each of the 1st 3.
bob.verwey(at)gmail.com
PostPosted: Thu Dec 07, 2017 9:53 pm    Post subject: Clever Wiring for Lamp Dimmer Reply with quote
Question from a neophyte....does the dimmer not create some kind of electrical "noise"?
Best...Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
On 8 December 2017 at 07:06, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Folks,
    -- Art Z.
Virus-free. www.avast.com [url=#m_1398500146610424097_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
PostPosted: Fri Dec 08, 2017 11:16 am    Post subject: Clever Wiring for Lamp Dimmer Reply with quote
Some do, most don't . . . but there is no 'general rule'
[img]cid:7.1.0.9.0.20171208131056.0580fd50(at)aeroelectric.com.0[/img]
Illumination feeders to multiple swithces
can be 'daisy cahined' with short segments
of wire crimped into the fast-ons as suggested
above.
Eric Jones offers a little dimmer assembly (noise
free) that would work nicely with this task.
https://goo.gl/ndNhX3
 Filesize:  74.37 KB
 Viewed:  7777 Time(s)
art(at)zemon.name
PostPosted: Fri Dec 08, 2017 12:59 pm    Post subject: Clever Wiring for Lamp Dimmer Reply with quote
Thanks, everybody.
    -- Art Z.
